Steve Hargreaves - Moderator Posted February 19, 2013 Share Posted February 19, 2013 I have this ESC....it works fine but I want to switch the brake on. The manual is here......written in not brilliant English it must be said..... I can get it into program mode & I get all the relevant beeps very clearly but then how to actually set the thing......in the manual it says "confirm & reserve your settings" which I take to mean "save your settings" but sadly omits to mention how..... Can anyone help or do I need to buy ANOTHER programming card... Quote Link to comment Share on other sites More sharing options...
Pete B Posted February 19, 2013 Share Posted February 19, 2013 Moving the throttle stick to the bottom once you've got the correct number of bleeps normally saves the setting, Steve. Pete Edited By Pete B - Moderator on 19/02/2013 11:02:55 Quote Link to comment Share on other sites More sharing options...
Pete B Posted February 19, 2013 Share Posted February 19, 2013 A quick look at the instructions shows details in para VI; Switch on Tx, move throttle to high, connect ESC, one bleep after 2 seconds. This is followed by four short bleeps - move the throttle stick to close, a bleep should confirm the setting. With the brake, it just cycles between on and off each time you change it Now I've got to go flying....... Pete Quote Link to comment Share on other sites More sharing options...
Biggles' Elder Brother - Moderator Posted February 19, 2013 Share Posted February 19, 2013 Yeap - manual programming is usually done via the throttle stick. Throttle fully open, turn on, ESC enters programming mode, listen for the appropriate combination of bleeps, then whizz the throttle closed and that toggles the setting - ie brake on or off. BEB Quote Link to comment Share on other sites More sharing options...
Tangental Posted February 19, 2013 Share Posted February 19, 2013 3 moderators on the case! Hobbyking will be proud! Quote Link to comment Share on other sites More sharing options...
Biggles' Elder Brother - Moderator Posted February 19, 2013 Share Posted February 19, 2013 As long as people don't reach the conclusion that it needs three moderators to sort it out! Q. How many moderators does it take to progarmme a ESC? A. Three. One to do the programming, one to sort out the dodgy picture formating and one to check that the other two stay within the CoC. BEB Quote Link to comment Share on other sites More sharing options...
Steve Hargreaves - Moderator Posted February 19, 2013 Author Share Posted February 19, 2013 You should know we always work in threes Tangental......one Mod to do the work & another two to watch.... Yeah thats how I interpreted it too......Throttle stick to max & connect battery....I get a beep & then the sequence starts....I get the A beeps......then the B beeps & during the B beeps I lower the throttle stick & get two beeps & then...nothing.....moving the throttle stick has no effect & dis & reconnecting the battery puts me back where I started.....ie without a brake..... Very frustrating......maybe I need to wait until the 4 B beeps have ended & then lower the stick.... Quote Link to comment Share on other sites More sharing options...
Biggles' Elder Brother - Moderator Posted February 19, 2013 Share Posted February 19, 2013 Yes - try that. There should be a short pause between the sets of bleeps. BEB Quote Link to comment Share on other sites More sharing options...
Myron Beaumont Posted February 19, 2013 Share Posted February 19, 2013 Makes you wonder just what aeromodelling really means doesn't it . Quote Link to comment Share on other sites More sharing options...
Steve Hargreaves - Moderator Posted February 19, 2013 Author Share Posted February 19, 2013 Ha......!! Sorted it...... I had interpreted the "manual" correctly but it needed the throttle stick trim right down as well to recognise it as throttle down & initiate the change...... I used my servo tester & this worked fine so then the penny dropped & I tried it using my transmitter but with the trim fully lowered too & hey presto it worked...... One to remember for the future methinks!!! Quote Link to comment Share on other sites More sharing options...
Olly P Posted February 19, 2013 Share Posted February 19, 2013 Ah.... I have to say I have started using the sefo tester to set ESC's - mainly as I am lazy and the Tx is normally at the other end of the bench! Quote Link to comment Share on other sites More sharing options...
Glyn R Posted March 4, 2013 Share Posted March 4, 2013 I have to say I use a programming card every time. I do use a servo tester to set up servos though. Quote Link to comment Share on other sites More sharing options...
