Gear Drive Reductions
Hello All as promissed here is a preview of the gear reduction ( mounted on the first into the US delivered Kolm IL 135 !!
4 years 2 guys adicted to giant scale (warbirds) had a talk and this became a giant professional project
2013 will be the launch of our "dream"
making geardrives for the scale modelbuilder for any big scale engine
so here is what to come
testsflights and data in
Yellow aircraft P 40 MVVS 40 + GD
Meister Scale P 47 MVVS 80 +GD
Carf P51 + Kolm IL 135
Giant Stick full data testplane with different props ( Vogelsang, Seidel)+ ZDZ?DA, DLE, engines
Launching website
and oh yes we are planning a......planetary geardrive....!!!!!wink
All coments and reactions are added value so stay tuned please
Happy Landings
  • 4 weeks later...
  • 2 months later...
Yes!!
We planned to use a Solo hub and blades but we dropped that plan and use other blades. It is also planned to use our own hub. I will post all info on the reduction and blades used, telemetrie etc after final test flying and by the launching to the public. All is in finishing stadium. Please stay tuned and thanks for the intrest!!
Gerrit
Hi all,
Here a youtube link to my companion who makes it all happen his name is John Munson and lives in Washington State. You can see the P 40 flight and test run with gear reduction, and the Evolution on the test stand and our new test beast with the Kolm IL 135 with the Sep prop next we will use Seidel blades...stay tuned
**LINK**
Hi Gerrit,
Have you done anything with shaft drives? I'm toying with the idea of one for the rear engine of an ESM Dornier 335. This has been done by a German kit manufacturer for a larger model of the same aircraft so it is possible. I'm looking for information on things like shaft couplings suitable for this sort of service but most of the outfits here are only used to industrial stuff, eg higher powers but much lower speeds. The shaft itself would need to be about 800 mm long, the engine would be a 120 four stroke.
John
  • 2 months later...
AND HERE IT IS ! REDUCTION FOR DA 60 and others :
Since the last post and the flying season is in full we managed to put out and test the reduction for so many guys and their beautifull scale birds ! This allows you to swing a scale big prop and go away from the static props.
Have a look pass it on and if you are interrested here you can put yr quieries ore send me a pm
[email protected]
**LINK**
We hope you all have a great season enjoy your meetings and fly in's and wich you many happy landings!!!!!!
Stay tuned !!!!!
Gerrit
Hi All,
The work goes on and the building as well.
here some pics of the DA 60 on the test stand and the Kolm 135 with gear in the comp arf P 51
and you have the test of the Kolm 135 with reduction
**LINK**
Q&A? just send me a mail, and by the way if you want one ( gear reduction that is..) just drop me a line
Stay tuned and enjoy
Gerrit
  • 1 month later...
Hi All,
as promissed we keep you posted
So here it goes
our reductions went on teststands and are fantastic:
Here is the list of engines for now
Kolm 65-100-135
ZDZ 80-90
DA 60 and later on 80
MVVS-Evolution 46 80
We also produce custom build
the reductions went all up in the air ....last engine was the ZDZ 80 unfortunately a transmitter brown out caused fatal crash of the giant Extra airframe and electronics....to our big estonishement after a cleanup of the engine and reduction and a new prop we put it on the teststand and it opperated flowlessly without any mechanical ore other intervention. Note the motor and gear were literally buried into the soil.
A new system Jeti DS 16 is on the way together wit all the electronics and telemetry the non reliable JR sytem was sold and all the electronic stuff was made redundant and is of now on a past.
So here a film of the ZDZ 90 after cleaning and restart on the teststand .
Sorry here is the film
**LINK**
If anyone needs a reduction or has Questions just drop me a line
[email protected]
we ship overseas !!
Wish you all happy landings and a good building season!!
Next news will be from The Sinnesheim Show in Friederichshafen Germany were I will introduce the reduction and visit my friends Hans Kolm( engines) and Mario Seidel (scale props and planetairy reduction for Moki 250) ( please vitit their sites) Stay tuned
Gerrit
  • 2 months later...
Hello Gents,
Latest News:
We started the firm JGM DESIGNS ( home base is Seatle USA/Boeing Country we will be machining ultra fine small parts for avaiation and automotive and RC. Europe OPS is yours truly home base Belgium
We now made and produce reductions ( custom made as wel) for following engine range:
All kolm single and IL engines ( also the 200 and...)
ZDZ 80 - 90
MVVS_Evolution all single engines as from 45CC
DA 60 80 more to come
Variable pitch is in motion status...first plans
As of now all test results in flight are monitored by Jeti DS 16 RX full range of telemetry
Carf P 51 ducting is completed and 135 is installed slick and smooth fit!! Ducting and reduction will be available as a complete set for the Kolm and Carf P 51
We build a reduction for the KOLM 150 IL 3 cyl ( working is perfect) going to Norway...will be for a Me 109 with a 34 scale 3 blade prop ( just awesome)
We recommend Seidel Props and blades ,( just have look on his side...concerning reductions ( Mario Seidel builded a planetairy reduction for the Moki Radial= available now)
So any Q & A please mail me Just visit the above links; we have the website now in testing mode and are waiting for aditional flight info ( good weather conditions) and we launch
Thanks for watching and stay tuned
Gerrit
JGM Designs Europe Ops
  • 1 month later...
