2.4Aerial
Steve Goodwin
Hi Steve,
Me personally (futuba fasst rxs) I use some short lengths of thin plastic tube glued into the fuz where you want the 90 degrees to be.
Then just put the aerials inside them. I tend to arrange it though so that the final inch or so ( the exposed/unsheathed ends) protrude out of the tube.
Craig
Edited By Craig Carr on 24/09/2013 07:34:47
+1 for drinking straws to hold them in place.
Also make sure you route them away from any sources of electrical noise if possible.....servos, ESCs, Ignition models etc all put out electrical "noise". In practce 2.4GHz is usually higher than any RF noise generated by such items but best practice & all that....wink 2
Posted by Steve Hargreaves - Moderator on 24/09/2013 12:15:48:
Good practise but not always possible, I've used the Orange DSM2 Rx's mounted right next to the ESC with no issues a Spektrum DSM2 rx between the ESC and motor (EDF) with aerials close to the electrical parts and several electric planes with the single aerial M Link Rx's and not had a hint of bother. One of the planes was a real pain on 35mhz and still glitched which was cured by moving to 2.4.
The important thing is to do a power on a range check.
Edited By Frank Skilbeck on 24/09/2013 12:57:47
