Gary Vinten 1 Posted September 28, 2013 Share Posted September 28, 2013 Hi all this is my latest build from a plan Thde Mirarge F1 syle jet itis set up to be powered by a pusher engine . The motor will be coming from Rapid RC (helli motor) apc sport prop 6.5x6.5 at 75amps giving about 1100 watts on a 4s 5000 50c. The jet is all balsa construction covered in polly c then painted with rattle cans not sure of the auw yet waiting for the motor . the battary on the nose is to hold the jet down as there is not lipo fitted yet Quote Link to comment Share on other sites More sharing options...
kevin b Posted September 28, 2013 Share Posted September 28, 2013 Very smart model Gary. Good luck with the maiden. kevinb. Quote Link to comment Share on other sites More sharing options...
David Tweddle Posted September 28, 2013 Share Posted September 28, 2013 Hi Gary and thanks like it a lot What is the size (slabs 14" - 16", plan etc. Would have loved to have seen the build Inc cover/finish though. David Quote Link to comment Share on other sites More sharing options...
Gary Vinten 1 Posted September 28, 2013 Author Share Posted September 28, 2013 HI David I do have the photos on the build but my phone has gone in for repair when its back i will post them the jet sizes are wing span 34 " nose to tail 43" weight should only be about 3.5 / 4 LB Quote Link to comment Share on other sites More sharing options...
Gary Vinten 1 Posted September 28, 2013 Author Share Posted September 28, 2013 Iam going to put agiro in this one after reading the artical in the rcm@e special Quote Link to comment Share on other sites More sharing options...
Ben B Posted September 28, 2013 Share Posted September 28, 2013 Wow- that looks good and fast. What's the wingspan? Are the side ducts going to be used to cool the battery / ESC? Quote Link to comment Share on other sites More sharing options...
kc Posted September 28, 2013 Share Posted September 28, 2013 Gary, you said it was covered in Poly C ....do you mean glasscloth / tissue & Poly C or just Poly C ?Whatever, it looks great. Quote Link to comment Share on other sites More sharing options...
Gary Vinten 1 Posted September 28, 2013 Author Share Posted September 28, 2013 Hi Ben The battery will be cooled from the front from openings under the fuz. The esc and motor will be cooled from the back by a scoop that will be hidden Quote Link to comment Share on other sites More sharing options...
Gary Vinten 1 Posted September 28, 2013 Author Share Posted September 28, 2013 Hi KC Poly c lightweight fibre glass cloth Quote Link to comment Share on other sites More sharing options...
Biggles' Elder Brother - Moderator Posted September 28, 2013 Share Posted September 28, 2013 The finish is excellent Gary. Lovely looking model. Looking forward to seeing some flying shots from the maiden! BEB Quote Link to comment Share on other sites More sharing options...
Gary Vinten 1 Posted September 28, 2013 Author Share Posted September 28, 2013 Thanks beb Will try and vid the maiden but not sure when Quote Link to comment Share on other sites More sharing options...
Gary Vinten 1 Posted September 29, 2013 Author Share Posted September 29, 2013 What do people think about giros in planes and has anybody fitted one as I intend to fit one on the mirage and was looking for some feed back on what they were like. Quote Link to comment Share on other sites More sharing options...
Ben B Posted September 30, 2013 Share Posted September 30, 2013 I know people who have used them. Mainly for preventing massive swings on take-off or with high power planes to prevent torque rolling when you open up the gas. I was going to install on in a funjet but it gets a bit more complicated with elevons as you have to have a v-tail mixer after the gyro and then you lose some of the mixing features the transmitter has. Quote Link to comment Share on other sites More sharing options...
Gary Vinten 1 Posted September 30, 2013 Author Share Posted September 30, 2013 thanks for that Ben some more photos The motor has now turned up so now on to fitting and testing Quote Link to comment Share on other sites More sharing options...
ken anderson. Posted September 30, 2013 Share Posted September 30, 2013 hello gary--and very nice too...well done... ken anderson ne..1........well done dept..... Quote Link to comment Share on other sites More sharing options...
GrahamC Posted September 30, 2013 Share Posted September 30, 2013 Gary... the finish does look exceptional on that... I'd love to know what stages you went through and what materials you used. Are you using automotive filler? Edited By GrahamC on 30/09/2013 19:05:08 Quote Link to comment Share on other sites More sharing options...
Gary Vinten 1 Posted September 30, 2013 Author Share Posted September 30, 2013 Hi graham No the only filler I use is light weight balsa filler , it's a little late tonight but I can run it of for you tomorrow Just thinking I did use primer filler then rubbed back Quote Link to comment Share on other sites More sharing options...
GrahamC Posted October 1, 2013 Share Posted October 1, 2013 Which balsa filler are you using - I've used lightweight decorator's filler and maybe that's my problem. Quote Link to comment Share on other sites More sharing options...
Gary Vinten 1 Posted October 1, 2013 Author Share Posted October 1, 2013 Hi Graham I use lightweight decorator's filler as well with no problems, as long as you let it dry . I then gave it a coat of polly c to seal it rubbed down with 800grade . then added light weight glass cloth and 5-8 coates of polly c until the weave has gone . Then one coat of filler primer rubbed fully back . Then white undercoat acylic sanded to a smooth finish then a top coat of red acylic spray paint and that is it!!!!! needs a little practice but does give you a strong and light weight finish Quote Link to comment Share on other sites More sharing options...
Gary Vinten 1 Posted October 8, 2013 Author Share Posted October 8, 2013 Hi All This is a update on the motor Turnigy 500 H3126 Brushless Outrunner 1600KV has a 5mm shaft so fittinf a small prop is no problem Quote Link to comment Share on other sites More sharing options...
Victor Saliba Posted October 8, 2013 Share Posted October 8, 2013 Hi Gary, well done, very nice finish. Keep us up-dated and good luck with the test flight. Quote Link to comment Share on other sites More sharing options...
Gary Vinten 1 Posted October 8, 2013 Author Share Posted October 8, 2013 Thanks Victor Will keep all posted when it happens Quote Link to comment Share on other sites More sharing options...
