john stones 1 - Moderator Posted June 15, 2014 Author Share Posted June 15, 2014 I checked Colin, when I left home I had a braincell Lost in transit...will be sorted soon. John Quote Link to comment Share on other sites More sharing options...
Gary Manuel Posted June 15, 2014 Share Posted June 15, 2014 Checked twice eh John Quote Link to comment Share on other sites More sharing options...
Gary Manuel Posted June 15, 2014 Share Posted June 15, 2014 Posted by Phil Winks on 15/06/2014 23:02:02: I Think you may be right Gary not sure why I said series never been a fan of parralell btys with out a schottky diode in line to prevent back charging, one may have helped here but also the voltage differential would prob have blown the diode any way Phil, May not be as costly as he thought. The ESC and motor may only have suffered smoke damage as they would not have been the cause of the Chip (pan) fire. He might get away with re-using these. Quote Link to comment Share on other sites More sharing options...
Phil Winks Posted June 16, 2014 Share Posted June 16, 2014 the motor may have survived but the esc was not only just below the batteries and it was the nearest one that went but a lot of the current would've passed through it the main leads were certainly desoldered and given the bty was 20mm behind the motor my guess is it suffered major heat trauma too temperatures in there must've been knocking on the thousand degree mark for a few seconds Quote Link to comment Share on other sites More sharing options...
john stones 1 - Moderator Posted June 16, 2014 Author Share Posted June 16, 2014 Well damage is not so bad, should be fettled by tomorrow night then a touch of staining to do, hopefully the motors o.k. it crashed nose first, but the grass was very soft. soon find out when I test fly again, have checked it over seems alright. Only a jet to go then I've bent every kind of model John Quote Link to comment Share on other sites More sharing options...
Phil Winks Posted June 16, 2014 Share Posted June 16, 2014 if the motor's running smoothly with a balanced prop on then it's most certainly ok, Time to buy a jet then John Quote Link to comment Share on other sites More sharing options...
Biggles' Elder Brother - Moderator Posted June 16, 2014 Share Posted June 16, 2014 Oh John, sorry I've only just picked up on this. That's bad luck - I guess she just stalled and flicked in on you. The DF does fly very well - which I suppose does encourage us to take a few liberties! But of course there is a limit to even the most docile aeroplane's tolerance - and sadly it looks like you found it. Still as you say I think she's fully repairable - as I'm sure you know, at first glance it looks much worse than it turns out to be when you get it on the bench. Good luck getting it back into flying fettle for next weekend! BEB Quote Link to comment Share on other sites More sharing options...
john stones 1 - Moderator Posted June 16, 2014 Author Share Posted June 16, 2014 It'll be done BEB, was no bad luck just got too cocky planes a good one, pilots a numptie, yes it flicked in, my fault. It's sat waiting for glue to dry, be done tomorrow John Quote Link to comment Share on other sites More sharing options...
Devcon1 Posted June 17, 2014 Share Posted June 17, 2014 Well done John, Repairing quickly does seem to be the best plan.. Quote Link to comment Share on other sites More sharing options...
john stones 1 - Moderator Posted June 17, 2014 Author Share Posted June 17, 2014 All done, just restaining to do Yes Gary checked twice, you know my p.c skills well Whilst we are on subject of Greenacres, hows about you making numbers up ? John Quote Link to comment Share on other sites More sharing options...
Gary Manuel Posted June 17, 2014 Share Posted June 17, 2014 John, Normally I would have loved to make the numbers up at Greenacres and I have a few suitable electrics, but I'm still sick at the moment. Not coping very well with mornings or long days Quote Link to comment Share on other sites More sharing options...
john stones 1 - Moderator Posted June 17, 2014 Author Share Posted June 17, 2014 Hope your better soon....morning sickness eh I can give your models an airing for you Gary...i'm very careful John P.S. not got a jet have you Quote Link to comment Share on other sites More sharing options...
