john melia 1 Posted May 29, 2014 Share Posted May 29, 2014 Can anyone help with this engine, its a super tigre 61 as far as i can make out. I've looked at the carb high needle assembly and it looks a bit weird to me, are they supposed to look like this Quote Link to comment Share on other sites More sharing options...
Jimbo565 Posted May 29, 2014 Share Posted May 29, 2014 John Thats the way it is, its an older engine and those needles are quite difficult to come by at present, I have known them to made from bicycle spokes. the newer engines have a main needle just like the low end one. Jim Quote Link to comment Share on other sites More sharing options...
Engine Doctor Posted May 29, 2014 Share Posted May 29, 2014 Just to second that . Those needles are now unobtainable unless your very lucky to find some in old stock tucked away somewhere. The newer carb is a straight swap but probably costs more than the engine is worth. On your pic of the fuel inlet to the carb , it appears to be set up wrong. Try running it and if it idles and picks up ok then leave it; but if idling is a problem the loosen the two black screws slightly and turn the brass unit so that the inlet nipple (where the fuel tube pushes on) points at the front mounting hole on the crankcase. Quote Link to comment Share on other sites More sharing options...
Bob Cotsford Posted May 29, 2014 Share Posted May 29, 2014 It's an S series ST, the S61 I had ran and throttled ok but not exceptional power-wise. The brass thimble nut over the needle is like a gland nut on a tap, it adjusts the tension on the needle. Quote Link to comment Share on other sites More sharing options...
john melia 1 Posted May 29, 2014 Author Share Posted May 29, 2014 Thanks guys, this engine is installed in a super stearman bipe, i could always take it off and bin it and put an asp 61 on instead ?? Quote Link to comment Share on other sites More sharing options...
john stones 1 - Moderator Posted May 29, 2014 Share Posted May 29, 2014 Give it a whirl John, Super Tigre usually reliable, may be a bit throaty though. John Quote Link to comment Share on other sites More sharing options...
Hangar 9 nut Posted May 29, 2014 Share Posted May 29, 2014 Try Dave at Motors and Rotors he used to import ST's and he still has some old stock ! Quote Link to comment Share on other sites More sharing options...
Jimbo565 Posted May 29, 2014 Share Posted May 29, 2014 Put the needle on ebay, make a fortune Quote Link to comment Share on other sites More sharing options...
Shaunie Posted May 29, 2014 Share Posted May 29, 2014 I had one of these (still got it, awaiting restoration) which I ran in a Masterline Vandal with a tuned pipe. It went like a scalded cat (by late 80s early 90s standards anyway). Throttled beautifully, you can alter the transition from idle to power by turning the brass spray bar assembly. This is flattened slightly if you look through the venturi and has a slit jet in the bottom (you will only see this with the carb off). That should give you an idea if it's fitted correctly. Shaunie. Quote Link to comment Share on other sites More sharing options...
