Gary Murphy 1 Posted June 19, 2014 Share Posted June 19, 2014 As anyone had any issues with CG using 3s setup. Just ordered a kit and when ordering the motor from a good vendor I was informed that the kit as known issues with loads of weight needed to get cg right.He said ripmax were aware some time ago and its proberly addressed by now.But I was warned that if you get a bad kit 4s is needed which I do not want to do. Any feedback from owners would be great,recent buyers would be good also if anyone did get a so called heavy one did it require 4s to offset the weight. Quote Link to comment Share on other sites More sharing options...
John Goodwin 2 Posted June 19, 2014 Share Posted June 19, 2014 I have encountered this problem. I ended up with a 4s battery Quote Link to comment Share on other sites More sharing options...
Gary Murphy 1 Posted June 19, 2014 Author Share Posted June 19, 2014 I should of stated its the balsa NOT foam model,just to be sure. One already,the shop was correct by the sounds of it.Rang Ripmax to ask and was not given any useful details. Quote Link to comment Share on other sites More sharing options...
Paul C. Posted June 19, 2014 Share Posted June 19, 2014 Hi Gary I have a wot 4 e balsa just finnished putting the gear in. The balance point in the instructions is wrong should be 90 cm from the leading edge but check the ripmax site to be sure they never corrected the instructions. I am using 4s and an emax BL 2826/06 motor model is just over four pounds in old money. There is a great thread somewhere in the build heading gives great info. Not flown mine yet but balances bang on with the bigger batteries and bigger motor (had to shorten the motor mount to fit it in the cowl but no big deal) no added lead. To be honest the balsa wood used in the kit is the hardest and heaviest I have ever encountered and the nylon fittings went straight in the bin and I bought new. Will try to ring a link to the build for you but I am not very good with the search function might take a while Quote Link to comment Share on other sites More sharing options...
Paul C. Posted June 19, 2014 Share Posted June 19, 2014 That should be 90mm by the way slight slip of the finger. Quote Link to comment Share on other sites More sharing options...
Gary Murphy 1 Posted June 19, 2014 Author Share Posted June 19, 2014 Cheers Paul,thanks for the info,been looking on line and it seems most people have the weight issue.flies pants when heavy and on 3s. For me I want to use 3s and not 4s so I am going to return mine,i was lucky and was able to catch befor despatch. Quote Link to comment Share on other sites More sharing options...
Masher Posted June 19, 2014 Share Posted June 19, 2014 I had to add quite a bit of weight to mine using 3S and 90mm. Now expired so can't check how much Some of my clevices broke in the hand - need to check all supplied fittings Quote Link to comment Share on other sites More sharing options...
adrian lawrence 1 Posted June 19, 2014 Share Posted June 19, 2014 Much the same as Masher with my crevices, also bending the elevator push rod caused it to snap. I made up a new one and used metal screw on clevises. I used a larger motor, 4 cells and over 100gms of lead to balance at 90mm. this is because the whole fuselage from the wing trailing edge aft is heavy birch ply, weight and strength where you don't need it. It's worth glass in ground the undercarriage mounting plate as this easily rips out (don't ask why I know). The model flew ok but was fairly fast due to all the weight, lots of birch ply in the wings too. hope yours goes well, adrian Quote Link to comment Share on other sites More sharing options...
Ian Mat Posted December 11, 2014 Share Posted December 11, 2014 I have just started learning to fly on the same model. I have added about 90g of lead in the nose and she still flies great on a 2200 mAh 3 cell battery. I didn't want to go for 4 cell batteries because I have so many 3 cells already. I was initially against putting all that lead in the nose, but I assure you that trying to fly it with the CG too far back is very difficult. That is the opinion of the club expert who trimmed it out for me! Even with the extra weight she flies as slowly as you could ever want and is very easy to land. with a 11 x 6 prop she has plenty of power as well and takes off after about 3m run on grass. My advice is not to worry about the "dead weight" if the model had come with it already fitted, no one would be complaining about the performance! Quote Link to comment Share on other sites More sharing options...
Masher Posted December 11, 2014 Share Posted December 11, 2014 If being used as a trainer, I probably agree with you Ian. Unfortunately this version is very pedestrian compared to all the other WOT's which can be very sprightly if required so anyone thinking it might be like a foamy WOT beware - it's much heavier and slower. Quote Link to comment Share on other sites More sharing options...
Joe Beavis Posted December 11, 2014 Share Posted December 11, 2014 I also had been alerted to the heavy back end, so I used an 810kv OS motor and poked it straight through the cowling. With a 3300 4s battery it balanced properly. They call it "balsa", but repairs have shown very little evidence of what we normally think of as balsa. You could dig a trench with the wing! All Chris Foss designs fly well, but it was hard to fall in love with this model. Mine usualy stopped a spin instantly the sticks were centrallised, but one day it found a whole new level of spin - almost a blurr - I gazed in wonder for a second too long, and it is now in the 'repair pending, perhaps' box! Capably flown one of these could last a long time, and it has to be good value at the price. Newcomers might be wise to convert to banded wings, but in my opinion that goes for any smallish models. Quote Link to comment Share on other sites More sharing options...
Ian Mat Posted December 11, 2014 Share Posted December 11, 2014 My biggest criticism is the flight time on a 3 cell battery, but this isn't leveled at the model itself and is probably a result of the cheap batteries I'm using (turnigy 2200mah). Just when I'm getting the hang of the flying, it's time to land, which is why I'm currently building a normal sized Wot 4 kit with a glo engine. Quote Link to comment Share on other sites More sharing options...
