Jim Newberry - Nuviation Ltd. Posted July 24, 2014 Share Posted July 24, 2014 Hi Folks, I've been busy with Turbocad again and drawn up plans for the next OD sports model. This time it's a semi aerobatic biplane of 60" span called Flikamoka. In case you were wondering where I got the name from, that's what my 4 year old daughter calls sycamores when we play with them. Anyway, here it is - please let me have any comments, good or bad. Construction is mainly from balsa and lite ply, I'm aiming for an all up weight of around 5-5.5lbs and electric power. Edited By Jim Newberry on 24/07/2014 16:23:30 Quote Link to comment Share on other sites More sharing options...
john stones 1 - Moderator Posted July 24, 2014 Share Posted July 24, 2014 Looks good to me Jim, appears to be a long moment arm or it that just my eyes John Quote Link to comment Share on other sites More sharing options...
roger graves Posted July 24, 2014 Share Posted July 24, 2014 I agree re moment arm, fin/rudder look small, flat bottom wing section you will probably need negative incidence on tailplane. HTH Roger Quote Link to comment Share on other sites More sharing options...
Jim Newberry - Nuviation Ltd. Posted July 24, 2014 Author Share Posted July 24, 2014 Thanks for the input chaps. It's all good stuff. As it happens, the tail moment is slightly less than that of a Tigermoth. Roger - it's a slightly semi symmetrical section, the lower wing has an incidence of 1.5 degrees while the upper has 3 degrees. This is my first biplane design so I'd welcome anyone's input about thrust angles, CG, incidence angles etc. Best wishes, Jim. Quote Link to comment Share on other sites More sharing options...
Tony Bennett Posted July 24, 2014 Share Posted July 24, 2014 thats nice. lovely looking aircraft. Quote Link to comment Share on other sites More sharing options...
