SAAB Viggen 1/8th scale PSS
Andy Meade
Hi there guys and gals!
Well, after the Lleyn meet I realised that the Jim Fox Viggen that I had sat on my "long term build" bench was just not going anywhere. I bought her off of eBay last year with the intention of going for 6 or 7kW EDF install, which with scale undercarriage (inline bogeys on the mains) would give me flight times of maybe 5 minutes tops on 10 or 12S lipos. I've loved Viggens for a long time (almost as long as my love for MiG 29's!) and I want to see one of my own in the air, so the decision was made. Why bother with 5 minute (or perhaps 10 minute with a turbine) flight times, when I can stay up for a hour or two at a time on the slope? Yes, PSS conversion beckons....
I say conversion, but this machine was never finished by its previous owners. The wing was finished in solartex over a glassed foam wing - the finish under the 'tex was horrible. The ducting and fin is all installed, but no radio bay or servo mounts. I do have a complete "before" pic somewhere, I will dig it out, but for now - to the build!
Here is the nosewheel cavity. I don't need no stinking undercarriage, so it's going.20140812_125100.jpg
Stick a block of bluey-pinky foam in there with thickened epoxy blasted through a syringe on the inside :
Carve, carve, sand and fill :
A touch of light glass :
Then Poly C the beggar on there :
The canards had the breaking strain of a Kit Kat, so out the came, and a hardwood spar was introduced through some lovely looking ducting :
inside :
Slots relieved in canard, and CF anti rotation pins added to the front too to stiffen things up a bit :
Huh, CF rods aren't in that picture. One of the canards needs a little LE adding back in, but will detail that in the next installment.
Controls will be elevons, canards on the throttle stick or 3 position switch, rudder, and hopefully some scale embellishments. Power will be two large 6v packs, or maybe two 3S lipos as far forward as I can get them.
Colour scheme will be the lovely, classic splinter :
Edited By Andy Meade on 13/08/2014 14:09:34
Hi Jamie,
Not sure! It's a big wing, but it's extremely thin, with a razor like LE. I shall take the LE off anyway as it's a bit dented, then replace it with hardwood - with the wing so low she'll be skidding in on it with one of trademark heavy landings. On a coastal site, I'd like to say 15 for mooching about, 20 to be great, 25mph winds to be ballistic.
Thanks for the reply - I'll keep the pics coming in fits and starts, as I tend to build a lot and take pics quickly, then upload them a few days later with the description.
edit to add :
I thought about the wing a lot over the last few days, and I'd like to cut another with a slightly more "slopey" section, but would have to re-do the huuuuuge fuselage fillets if I were to go that way.  I don't want to do that because all of my fillets look awful.
Tonight I shall mostly be cutting the fin to make a rudder, and maybe some blending work around the poorly fitting cockpit base.
Edited By Andy Meade on 13/08/2014 14:19:08
It actually is not that far from completion - most of the work will be in the wings and finishing. I hope to have her ready for the October Orme meet. The PAK however...might be April 2015. I am using up a lot of brownie points as it is trying to get my 4th PSS build of the year complete!
Don't tell her I'm also going to re-finish my Howard Metcalfe Models F4 for October either... angel
Is there any where good to look for a jet kit for PSS. Do you guy's prefer glassing the wings for that extra weight and strength for sloping. Are you going for a grey colour scheme. It might be a bit troublesome against a moody sky frown....sorry about all the questions lol. I'm just finding my feet with the whole slope thing. Did it years ago and have just recently started trying it again .
Always good to ask questions Jamie
PSS kits are far and few between these days, good ones I know of are from here :
http://www.islandmodels.ie/index.php/pss
I've seen them both fly and they perform well. Glassing wings isn't really a necessity, it depends a lot on where you fly from most, how great your landings (arrivals!) are, and what sort of finish you're after on the completed model.
Grey underside shouldn't be a problem - I can always turn the nav lights on if I get disoriented wink
OK so a bit more progress. I cut the rudder from the fin, as per looking at a 3-view of the full size. Front faces sheeted in 3/16" hard balsa, top and bottom faced in 1/16th" ply :
I dropped a shortened aileron bellcrank through the fuselage, pinned it to the fin with its bearings, then supported it inside with a large balsa block with a vee cut into it (not pictured yet). Rudder control will be a long snake going into the nose:
Here is a quick overall view to show her size - I have named her Ingrid the Big Swede (cutting mat is A4), and the canards are now glued to their new main spar, carbon dowels, and fuselage :
Here is a shot showing the inside of Ingrid's nosey where the undercarriage door has been blocked off :
Ingrid's bum is missing a protrusion that is on the full size. This probably holds something for rear looking IR? Certainly a nav light, anyway, so I am re-creating it with a 1/16" ply inner, and pink foam outer :
Now epoxied on, next to some inspirational piccies that I stuck around the workshop about 6 months ago - you can clearly see the blended protrusion in the photo :
That's it for now, hopefully lots of work over the weekend!
Nope, the retract units go straight through the wing. "Back in the day" there were no really slimline units, so the instructions say cut clean through, then put a blister on top of the wing to cover the retract. Horrible. I removed said blister, and all this area on top and underneath where the cutouts are will have expanding foam blasted into them before being glassed.
Not done too much that's exciting, so here is the only photo of note - protrusion is shaped, filled, and glassed :
I've worked on the wings a fair bit, got down to brass tacks (pretty much). It has been entirely glassed, but someone was so horrified by their handiwork (I know the feeling!) they Solartex'ed over the top of it. I have power sanded it as flat as I can get it, and will blow a thin layer of primer over things to see how good / bad it is. New LE's are ready to go on, then the decision will be made whether to solarfilm over the glass or fill/sand them into shape as is.
Servo tray has been cut and ready for nose install. Should get this done tonight, then the cockpit sides will be ready for P38 body filler to blend into the canopy sides better. Will fill around the canards at the same time, then the fus will be ready for final sanding and primer guide coats.
Things are moving well at the moment, the wing was "red-spotted" and rubbed back, just to see how smooth I could get the surface as I want to spray directly onto this one, without filming it first.
It seemed to go OK, so I used the expanding foam on the wheel wells, lightly filled them, then red-spot filled again, then hit it back again. Phew.
The cockpit area has also been built back up where the glass fibre had been chopped back too hard by a previous owner - now all filled and smooth. Canards received a bit of the red stuff too (can't get enough of it!) where things get bumpy around their new spar.
Pine LE's have been added now, so once they have been carved to shape (not knife edged like the previous ones), the wheel areas will be lightly glassed, wires will be let in across the TE for the nav lights, then it should be time for final fillering and sanding. Phew.
Yes the little Phantom is getting worked on at the same time in the background - she's just about ready for solarfilming the wings and fin, then go mad with the prymol, then priming. Just about on schedule still for the October meet.
Oh, and the Me262 has had it's nose renovated - have removed the "2" and the swastika, and will be re-applying them in a more appropriate size. Also the 4 x 30mm cannon have been added to the nose for a bit more detail, and the cockpit has now got a frame on it.
Non-stop PSS at the moment!!
It feels like it sometimes Mark!
this year I have so far completed 7 new builds, all from plans bar the JP which was assisted by a CNC kit. This should be 2 more, and will take my tally of PSS planes from zero airworthy in January to 5 by the end of the year, with another 4 planned for the first meet of the season next year! It is getting a bit silly, but I love it and at some point must do some house DIY, but I've managed to dodge that so far!
Anyone fancy an impromptu meet in December?
  • 4 weeks later...
20140929_080053.jpgWell, I was away on holiday for a week in the camper, so missed my sanding block and film iron so much, I decided to use them both all day yesterday, ha.
A quick shot of the Viggen and Phantom, after a quick wet and dry this morning. I stuck to the silver solarfilm / prymol / car primer formula that worked reasonably well on the Me262 on all the ailerons / rudders / elevators / canards / fins, and all over the F4 wing. The Viggen's wing has had a LOT of filling and sanding in progressive stages (a poor glass finish by previous owners unfortunately) but I decided to call it done as is. The Viggen fus is glass, so got a quick rub down then a breath of prymol on it before primer coat.
Time to fit the waggly bits on both airframes, then we are ready for some top coat action.
