J.N. Posted January 22, 2015 Share Posted January 22, 2015 Does anyone know where I can obtain a 2 pole connector similar to what is shown in the photo. This particular connector is part of my Yuasa battery charger. Similar connectors are common in the USA, and called Cole Hersee Universal Trailer Connector 2 Pole, or bullet connector, however, having connectors sent over from the USA is a very expensive option. I want to make up a couple of dedicated fitting charging leads to enable me to use the one charger for various charging needs and need to source some connectors, failing this type of connector does anyone know of an alternative. Thanks. Quote Link to comment Share on other sites More sharing options...
Brian Lambert Posted January 22, 2015 Share Posted January 22, 2015 Like these? Link Quote Link to comment Share on other sites More sharing options...
Phil Green Posted January 22, 2015 Share Posted January 22, 2015 We have the same problem with Optimates on the bikes - they have recently changed to that type of connector. So I just make the supplied tail into an adapter by snipping the battery end and fitting whatever is required - Tamiya model-car connectors are popular on bikes, both my lads are Tamiyas, mine has a DIN 2-pin speaker socket, some have a fag-lighter socket, I just make up whats needed. Another adapter to a simple pair of croc clips is always handy. Cheers Phil Quote Link to comment Share on other sites More sharing options...
J.N. Posted January 23, 2015 Author Share Posted January 23, 2015 Posted by Brian Lambert on 22/01/2015 22:52:14: Like these? Link Yes just like "these" however the postage is the problem. Thanks. Edited By J.N. on 23/01/2015 09:08:17 Quote Link to comment Share on other sites More sharing options...
Bob Cotsford Posted January 23, 2015 Share Posted January 23, 2015 Powerlet use to market these for m/cycle accessory wiring, I used them to supply power to accessory sockets in my tankbag. They seem to have fallen out of favour but I did find this one even better on Amazon - SAE 2 pole connector seems to be the key phrase Edited By Bob Cotsford on 23/01/2015 09:37:43 Quote Link to comment Share on other sites More sharing options...
Kevin Wilson Posted January 23, 2015 Share Posted January 23, 2015 Why mess about with obscure connectors that will always be a pain? Bash some XT60's or similar easier to obtain alternative. It is not as if you need any great current capacity. As Phil said, even rubishy Tamiya connectors would suffice. Quote Link to comment Share on other sites More sharing options...
gangster Posted January 23, 2015 Share Posted January 23, 2015 I use a similar arrangement to connect my field charger to a range of power sources cigar lighter caravan socket. ,croc clips 4mm etc. for this I use normal crimp on bullet connectors from the car accessory shop. Connected in the same way as your charger lead it is impossible to reverse polarity. It is also possible that they might interface with your existing lead Quote Link to comment Share on other sites More sharing options...
Brian Lambert Posted January 23, 2015 Share Posted January 23, 2015 Thanks bob that will save me loads of dosh. Brian Quote Link to comment Share on other sites More sharing options...
J.N. Posted January 23, 2015 Author Share Posted January 23, 2015 Posted by J.N. on 22/01/2015 20:56:32: SORTED. Found a U.K. source. J.N. Quote Link to comment Share on other sites More sharing options...
Essjay Posted January 23, 2015 Share Posted January 23, 2015 Probably too late now but Maplins have them Link Edited By Essjay on 23/01/2015 22:28:16 Edited By Essjay on 23/01/2015 22:28:39 Quote Link to comment Share on other sites More sharing options...
J.N. Posted January 24, 2015 Author Share Posted January 24, 2015 Posted by Essjay on 23/01/2015 22:11:21: Probably too late now but Maplins have them Link Edited By Essjay on 23/01/2015 22:28:16 Edited By Essjay on 23/01/2015 22:28:39 Thanks. Yes I have ordered 2 x sets from another source. It appears that I had the wrong description for the U.K., these connectors are called SAE and only known as trailer connectors in the specialized motor trade. Quote Link to comment Share on other sites More sharing options...
