Richard V-D Posted July 14, 2015 Share Posted July 14, 2015 Hi All Having never used any one of these before, I obviously did a bit of internet investigation beforehand. Came up with this. Use the glue to attach Koverall to frame. Heat shrink Koverall to tighten. Use non-shrinking dope to seal the weave before painting. Problem is I can only get shrinking dope ( they no longer produce non-shrinking apparently). Tried one neat coat of dope on a test piece and so far so good. However I still have doubts. Now for the questions:- 1) Just use neat dope to stick the fabric to the plane and forget the glue? 2) Should I not heat shrink the fabric and just rely on the dope? 3) Heat shrink and then use a 50/50 dope to reduce the shrinkage that will occur? 4) Use something else to seal the fabric. Your thoughts will be appreciated, plus any answers to questions I should have asked, but didn't 'cos I don't know enough yet The plane is the 1/3 scale Sig Spacewalker. ( I like a challenge ) Richard Quote Link to comment Share on other sites More sharing options...
roger graves Posted July 14, 2015 Share Posted July 14, 2015 Think non shrinking dope is available from full size aircraft suppliers try asking at your local airfield. Quote Link to comment Share on other sites More sharing options...
jrman Posted July 14, 2015 Share Posted July 14, 2015 Non shrinking dope is also available from "The Balsa Cabin". **LINK** Quote Link to comment Share on other sites More sharing options...
Richard V-D Posted July 15, 2015 Author Share Posted July 15, 2015 I'll be at Cosford over the weekend, so will hopefully pick some up. What about the heat activated glue/dope debate about sticking the edges down? Which do you find easier? Edited By Richard V-D on 15/07/2015 22:59:12 Quote Link to comment Share on other sites More sharing options...
jrman Posted July 15, 2015 Share Posted July 15, 2015 I prefer to use dope as the adhesive but have also used thin cyano rubbed through the Koverall with a suitably plastic gloved finger. If you go with the dope as adhesive use it neat. I've never had a problem heat shrinking and then using thinned shrinking dope but that has always been on substantial frames/wings. Nice to hear that people are still using the old ways. You'll be using bamboo instead of balsa next and then covering in silk! Quote Link to comment Share on other sites More sharing options...
Danny Fenton Posted July 15, 2015 Share Posted July 15, 2015 Richard I did as you suggest as one of your options, doped Koverall onto the rear section of a Brian Taylor Hurricane, shrank with some heat, just enought to make the fabric nice and taut. I then used two coats of shrinking dope over the top. However after a further half dozen thinned coats of none shrinking dope, I still had holes in the weave. The trick is to use a couple of coats of sanding sealer to fill the weave. Just for interest the model was covered about 4 years ago, and in the sun at greenacres last weekend a planned photo shoot had to be aborted due to the Koverall going all wrinkly! I have never heard of the stuff doing that The Koverall has subsequently recovered, however I will stick to nylon or silk in the future....... Hope this helps Cheers Danny Quote Link to comment Share on other sites More sharing options...
Richard V-D Posted July 16, 2015 Author Share Posted July 16, 2015 Thanks for the replies, they have helped a lot. I tested neat dope to glue the edges on a test piece and it worked really well. Tightened slightly with the heat gun, a coat of shrinking dope then a coat of sanding sealer. Brilliant! So dope it is. Cosford on Saturday to pick up bits and pieces, including some n/s dope. @jr Maybe birds feathers and wax? Quote Link to comment Share on other sites More sharing options...
Ernie Posted July 17, 2015 Share Posted July 17, 2015 What about banana oil? It's a non shrinking sort of dope. ernie Quote Link to comment Share on other sites More sharing options...
Richard V-D Posted July 19, 2015 Author Share Posted July 19, 2015 Hi Ernie, So good they named it twice! Was at Cosford yesterday and picked up a tin of n/s dope from the Balsa Cabin. They had all varieties there, including banana oil. Can recommend them. Quote Link to comment Share on other sites More sharing options...
