Stuart Z Posted August 10, 2015 Share Posted August 10, 2015 Can someone point me in the right direction please? I have an old OS 61 pumper that should be in good order albeit it has sat in a drawer for 25 years at a guess. It used to pull my F3A Calypso around at a rate of knots! Not crashed, but want to know if there is somewhere I can get it restored / freed up / cleaned up etc. Quote Link to comment Share on other sites More sharing options...
Bob Cotsford Posted August 11, 2015 Share Posted August 11, 2015 If it's just gummed up have you tried sitting it in a tub of glow fuel overnight? I have feed up castor gummed engines with WD40 in the past but I'm not sure how the rubber parts in the pump would react to that. so I'd stick to a soak in fuel and then warming it with a hot air gun on low, or a hairdryer. Quote Link to comment Share on other sites More sharing options...
Stuart Z Posted August 11, 2015 Author Share Posted August 11, 2015 Bob, Thanks for the reply, no I've not tried it as I don't have any - but it does sound like an option. I'll order some and give it a go. No reason to believe anything more serious , but as said above, it's been sitting a long time. Thanks Then all I need to do is sort out the tranny! Quote Link to comment Share on other sites More sharing options...
FlyinBrian Posted August 11, 2015 Share Posted August 11, 2015 Posted by Bob Cotsford on 11/08/2015 13:06:21: If it's just gummed up have you tried sitting it in a tub of glow fuel overnight? I have feed up castor gummed engines with WD40 in the past but I'm not sure how the rubber parts in the pump would react to that. so I'd stick to a soak in fuel and then warming it with a hot air gun on low, or a hairdryer. If the tranny is gummed up you can put that in the tub of fuel as well Quote Link to comment Share on other sites More sharing options...
bert baker Posted August 11, 2015 Share Posted August 11, 2015 I purchased an old open rocker Enya forty four stroke engine a few years ago. Yep castor oil fuel had gummed it all up. No compression at all, I left t in a ice cream tub full of fuel and occasionally brushed it with a tooth brush, left it for a good few days, removed and just cleaned off the muck from the outside of the engine. Lubricated the bottom end with air tool oil and cleaned out the carb jets, Ran it and flew with it. for a few years, still have it in the engine cabinet. Worst thing you can do is to try to turn it over before cleaning it Quote Link to comment Share on other sites More sharing options...
Stuart Z Posted August 11, 2015 Author Share Posted August 11, 2015 FlyinBrian -Guess I asked for that mentioning a tranny under the engine section! Got the engine free now 24 hours in oil and it still feels good and oily inside with good compression. So let's go from there. Thanks all. Quote Link to comment Share on other sites More sharing options...
bert baker Posted August 11, 2015 Share Posted August 11, 2015 I had a 90ish pump surpass and had to take the pump apart, It can be done but great care is needed. Quote Link to comment Share on other sites More sharing options...
Stuart Z Posted August 11, 2015 Author Share Posted August 11, 2015 Bert - thanks I may search for someone that knows what they're doing Quote Link to comment Share on other sites More sharing options...
