John Laverick Posted September 14, 2015 Share Posted September 14, 2015 Hi Guys, I think I have this configuration correct? Would like a second opinion before I blow 4 batteries up!!! i know I could just get two 8s and parallel them, but I like to utilize all my batteries if I can. Thanks John Quote Link to comment Share on other sites More sharing options...
MattyB Posted September 14, 2015 Share Posted September 14, 2015 Yep, all looks right to me - I hope you have a big charging bag/ammo box, that's a lot of power stored up! Quote Link to comment Share on other sites More sharing options...
Geoff S Posted September 14, 2015 Share Posted September 14, 2015 That looks OK. The black wire joining the 2 sets of batteries foxed me for a moment but it's just joining the negative of the LH pair to the positive of the RH ones. I prefer circuit rather than wiring diagrams I parallel a couple of 4S 3600 mAH LiPo packs in my Eezy Peezy, mainlky because I needed the extra weight to get it to balance and it's no problem - it also gives nearly 20 mintes flying time/pack. I think doing it your way is better because it gives greater flexibilioty with using your batteries with other modesl that are not quite so demanding of voltage/capacity. Curious, what's the application? Geoff Quote Link to comment Share on other sites More sharing options...
John Laverick Posted September 14, 2015 Author Share Posted September 14, 2015 Thanks guys, always nice to have reasurance ! Geoff, I'm electryfing the Hobby king.Pilot Rc S bach 73in, at least I hope I am!!!! I also need the weight of several batteries because I'll putting a motor in place of a 30cc engine. Model weighs 12pounds and I'm sticking a G110 motor in with a 100amp hv esc. John Quote Link to comment Share on other sites More sharing options...
John Laverick Posted September 14, 2015 Author Share Posted September 14, 2015 Sorry posted twice, fingers too fat for my tablet !!! Quote Link to comment Share on other sites More sharing options...
Simon Chaddock Posted September 14, 2015 Share Posted September 14, 2015 Isn't the G110 at 1800W is a bit low on power compared to say a DLE-30 at 3.7hp (2700W)?. Quote Link to comment Share on other sites More sharing options...
John Laverick Posted September 14, 2015 Author Share Posted September 14, 2015 Looking at the reviews and the different examples of set ups, the motor seems to be acceptable for my needs. Also a 3700 watt motor will frighten the bloody life out of me!!! Quote Link to comment Share on other sites More sharing options...
Frank Skilbeck Posted September 15, 2015 Share Posted September 15, 2015 We ran our Ampley tug on a Turnigy 275kv motor with an 8s battery and an 18x10 prop, it pulled 70 amps or so, around 1800 Watts, the Ampley weighed in at over 6kg and this combo would take it vertical. John, if you are not using them, you might want to consider the Jeti antispark connectors, I use them on all my 6s and above applications. Edited By Frank Skilbeck on 15/09/2015 14:10:48 Quote Link to comment Share on other sites More sharing options...
John Laverick Posted September 15, 2015 Author Share Posted September 15, 2015 Thanks Frank, that's exactly the set up I'm looking at. I'll get some of those anti spark connectors. I never get used to that big spark, even though I know it's coming!!! Where do you get them from? Thanks John Quote Link to comment Share on other sites More sharing options...
Stevo Posted September 15, 2015 Share Posted September 15, 2015 Squeeze one more battery in and you could power the full size Quote Link to comment Share on other sites More sharing options...
Frank Skilbeck Posted September 15, 2015 Share Posted September 15, 2015 Posted by John Laverick on 15/09/2015 16:13:48: Thanks Frank, that's exactly the set up I'm looking at. I'll get some of those anti spark connectors. I never get used to that big spark, even though I know it's coming!!! Where do you get them from? Thanks John I get mine from Electricwingman I use the 5.5mm ones as that's what I have on my SM Modelbau Unisens telemetry sensor. I'm sure it's kinder on the ESC capacitors than just whacking 32 volts straight across them, and it doesn't make me jump Quote Link to comment Share on other sites More sharing options...
John Laverick Posted September 16, 2015 Author Share Posted September 16, 2015 Cheers Frank, I took an ESC out of a plane to use on this one and hey presto it had an anti spark system on I didn't even know I had. As you say they work a treat, gives you confidence to bank your batteries John Quote Link to comment Share on other sites More sharing options...
