David Molineux Posted March 11, 2016 Share Posted March 11, 2016 I use a gas powered Iroda iron from Maplin. I got a heat gun tip for it too which is great for heat shrink. Also means I can use it at the patch if I need to (admittedly I never have but still...) Dave Quote Link to comment Share on other sites More sharing options...
Kevin Wilson Posted March 11, 2016 Share Posted March 11, 2016 Posted by Nigel Grant 1 on 11/03/2016 06:37:32: My heavy duty soldering iron that I inherited from my Dad has just burnt out and I need to get another one for soldering 8swg wire for undercarriage legs. Is the best idea just to get a 100w+ one with a heavy tip or are the ones with a wire loop like the Weller or Fuller ones OK? There is a Fuller brand on sale here (in NZ) available for a good price with a neat storage case. I have one of the Weller soldering guns. Never been very satisfied with it. I have seen them used with different loops for cutting foam, such as servo pockets, but I've yet to try that. I have lots of irons from 15w to 100w and the 40w temperature controlled iron does most jobs. My old fashioned thermal balance (uncontrolled element) 60w with 1/2" bit is handy for big connectors like Deans & XT90. Somebody mentioned resistance soldering, which is brilliant for putting brass sections together but not sure if it would be any good on cables. Probably OK on connectors where you can get the earth connection and the carbon on something solid. For undercarriage work I would probably replace your 100w Iron. Or a blowlamp (not one of those weedy pencil things, too hot with not enough heat). Quote Link to comment Share on other sites More sharing options...
Dave Hopkin Posted March 11, 2016 Share Posted March 11, 2016 Posted by Kevin Wilson on 11/03/2016 07:57:12:Or a blowlamp (not one of those weedy pencil things, too hot with not enough heat). "Too hot with not enough heat' How does that work then? Quote Link to comment Share on other sites More sharing options...
trebor Posted March 11, 2016 Author Share Posted March 11, 2016 I ended up getting a digital one from Maplins which can get quite hot but the tips are hollow alloy tubes. They are ideal for electronic things, heat up quick but for large undercarage wire they would be rubbish. Stick to good old solid copper tips or a pencil flame torch. Quote Link to comment Share on other sites More sharing options...
Jon Laughton Posted March 11, 2016 Share Posted March 11, 2016 I recently started using a Dremmel Versatip butane powered iron: it's brilliant! Quote Link to comment Share on other sites More sharing options...
Geoff S Posted March 11, 2016 Share Posted March 11, 2016 Posted by Dave Hopkin on 11/03/2016 08:16:48: Posted by Kevin Wilson on 11/03/2016 07:57:12:Or a blowlamp (not one of those weedy pencil things, too hot with not enough heat). "Too hot with not enough heat' How does that work then? I suspect he means thermal inertia when the heat dissipates quickly and so isn't suitable for bigger joints. When my Weller magnetically temperature controlled iron finally gave up the ghost after probably 40 years use - much of it professionally in the family TV business - I bought a Precision Gold A55KJ digitally controlled iron and station, probably from an eBay supplier. It has a variety of bit sizes and the temperature can be adjusted as required. I think it's 50 watts but I can easily use it to solder XT60 connectors. For bigger jobs I have a 120 watt Henley Solon I've had since I was about 16, so it's 60 years old. One thing I insist on is having a decent soldering iron and both satisfy that. Geoff Quote Link to comment Share on other sites More sharing options...
Dave Hopkin Posted March 11, 2016 Share Posted March 11, 2016 I use a butane pencil torch for Heavy weight wire, find it ideal much better than an iron as you can warm up a bigger area before getting the joint itself hot enough so the heat doesnt dissipate as fast - but in all soldering the secret is cleanliness and flux Quote Link to comment Share on other sites More sharing options...
trebor Posted March 11, 2016 Author Share Posted March 11, 2016 I've got a really old soldering iron that you heat up over a flame first in the shed somewhere, no thermostats, no cables, nothing to go wrong Quote Link to comment Share on other sites More sharing options...
Martin McIntosh Posted March 11, 2016 Share Posted March 11, 2016 This is quite old and may not look much but is the bees knees of professional soldering stations. The tip fitted is only 3/32" and the tube under 1/4" but it makes very short work of 6 swg wire as shown in the pic. The drawback is that one would cost you £250. I was lucky enough to `obtain` one. When I worked as a professional solderer I only used a Maplin digital station and there is no reason at all why one of these should not give the same results. No matter how large the job the thermostat will try to maintain the same temperature. Quote Link to comment Share on other sites More sharing options...
Luther Oswalt Posted March 11, 2016 Share Posted March 11, 2016 Martin - That is a beautiful soldering joint! You must be ask the "can you solder this for me" a lot! Leo Quote Link to comment Share on other sites More sharing options...
Nigel Grant 1 Posted March 11, 2016 Share Posted March 11, 2016 Thanks for all the advice everyone, and the illustration of how it should be done Martin. I'll be getting another 100w iron with a solid tip. Suns just rising here in Christchurch NZ and I've been down for a quick fly with my Mini Robot at the local sports fields before people start walking across it. Beautifully clear and calm with heavy dew showing we're on our way into autumn down here. Back home now with a coffee and couple of digestives as I type this out. Nigel Quote Link to comment Share on other sites More sharing options...
Geoff S Posted March 11, 2016 Share Posted March 11, 2016 You live in a beautiful part of the world, Nigel. I really liked Christchurch when we cycle-toured SI back in 1999 but that was before the dreadful earthquake. I had my last full size glider flight in the Southern Alps the same year, so lots of lift Enjoy the digestives! Geoff Quote Link to comment Share on other sites More sharing options...
