Bob Cotsford Posted July 4, 2016 Share Posted July 4, 2016 OK, as it says on the tin what options would forumites suggest for a Balsa USA Bristol M1. This is a 60" first war monoplane that the box quotes as 6-6 3/4lb flying weight, for 40-60 2str or 60-90 4str (load gulp at the upper limit suggestion!). Personally I think it's more like 40-45 2str or 60-70 4 str but what do I know? Anyway, I was looking at the stretched nose, 7" cowl and 5 3/4" wide fuselage and wondering what electric setup could provide extra ballast to allow for a shorter scale nose. A 15" prop would look about right. What do I have to hand - 6S 3700, 4S 3850 and 3S 2200 packs but only the 3S will fit across the fuselage without mods. A battery mount through both inner sides with a suitable hatch in the outer side might be an option for larger packs. Maybe a ring of 8 (4S2P) A123s round the inside of the cowl? Danny? Motors to suit? Please don't include 'OS' or 'MVVS' in the brand name, I ain't made of money! HK is my friend Edited By Bob Cotsford on 04/07/2016 11:31:42 Quote Link to comment Share on other sites More sharing options...
PatMc Posted July 4, 2016 Share Posted July 4, 2016 I've been watching this guy's progress he intends going with an Emax GT2826 710kv & 4s 4000 lipos. He was at the stage of decor last time I looked but he hasn't posted anymore since 28th April. The BUSA M1 is around the same size & weight as my Magnatilla. Power on that is a Turnigy 3548 900kv, 4s 4000 or 4s 2650 & 12x6 APC clone. AUW is 98oz , battery lives where the fuel tank used to, with access through the firewall via the cut out of the horseshoe shape cowl. Edited By PatMc on 04/07/2016 12:51:34 Quote Link to comment Share on other sites More sharing options...
Jon H Posted July 4, 2016 Share Posted July 4, 2016 Laser 70, 15x5 Turnigy type A wooden prop @ 9000rpm That will well overpower it though. A friend has a magnatilla flying on a saito 50 and we have propped that way up to keep the performance in check Quote Link to comment Share on other sites More sharing options...
IanN Posted July 4, 2016 Share Posted July 4, 2016 Posted by Bob Cotsford on 04/07/2016 11:30:13: OK, as it says on the tin what options would forumites suggest for a Balsa USA Bristol M1. This is a 60" first war monoplane that the box quotes as 6-6 3/4lb flying weight, for 40-60 2str or 60-90 4str (load gulp at the upper limit suggestion!). There were quite a few "lardy" builds of this one on the RC groups forum a while back. One of our transatlantic friends even put a 26cc petrol in his Quote Link to comment Share on other sites More sharing options...
Bob Cotsford Posted July 4, 2016 Author Share Posted July 4, 2016 Dear Gods, I take it the negative G maneuvers left a bit to be desired! I do have an ASP FS61, but that leaves it with the over-length nose and without the characteristic spinner - the spinners available are a bit flimsy for IC. Just fancied something I could throw in the car with just a couple of batteries and a transmitter. I was actually looking at 50xx motors just because it needs the weight up front and these are in the same ballpark as a 61 4 stroke. With these I reckon I could shorten the nose by about 1 1/4" at least if I can get the battery weight forward too,. Quote Link to comment Share on other sites More sharing options...
Bob Cotsford Posted July 4, 2016 Author Share Posted July 4, 2016 Pat, I'd seen that but 710kV motor turning a 14" prop still sounds like it would need a lot of ballast. I was wondering about something nearer 4-500kv for 4S or even lower for 6S, wafting a nice big prop round. Maybe on 6S 'wafting' might not be the best term to use? Quote Link to comment Share on other sites More sharing options...
PatMc Posted July 4, 2016 Share Posted July 4, 2016 Bob, he seems to have put a lot of thought into lightening the tail feathers, which might would help towards achieving the shorter nose. A heavier motor run with a prop/battery combo that's only a moderate load to it would help with the cg & reduce stress on the motor at the same time. If the target weight is 6lb, you're only going to need about 450W [My Maggie flies nicely on 460W at WOT]. With a suitable 15" prop, I'd estimate a motor weighing 200 - 250g, around 600 - 700kv on 4s & 400 - 500kv on 6s. Edited By PatMc on 04/07/2016 15:48:02 Quote Link to comment Share on other sites More sharing options...
Ton van Munsteren Posted July 4, 2016 Share Posted July 4, 2016 Hi Bob, Great model the Busa Bristol M1C, iam flying it for many years already. First with Nicad and a brushed motor and now with a geared brushless motor, batt is a Lipo 4S 4000ma and its just a great model to fly. Not 100% sure but I think the prop is a 16x8 with more than enough power to do WW1 aerobatics. Did a lot of modification to the model to get the weight down and made the wing in two panels. Here are some pics the rest is in my album **LINK** Ton Quote Link to comment Share on other sites More sharing options...
Bob Cotsford Posted July 4, 2016 Author Share Posted July 4, 2016 Thanks for the link Ton, you have gone to town on your M1! The clearviews and radiused root LE add a lot to the character. Did you shorten the nose on yours? I doubt I'll spend too much time changing the kit as it's intended as a knock-about model - or at least that's the intent at this point in time. Who knows what will happen once the kit hits the building board. ps - is that the Kavan spinner or the Traplet's one? Edited By Bob Cotsford on 04/07/2016 18:00:48 Quote Link to comment Share on other sites More sharing options...
Bob Cotsford Posted July 4, 2016 Author Share Posted July 4, 2016 Posted by PatMc on 04/07/2016 15:42:19: Bob, he seems to have put a lot of thought into lightening the tail feathers, which might would help towards achieving the shorter nose. A heavier motor run with a prop/battery combo that's only a moderate load to it would help with the cg & reduce stress on the motor at the same time. If the target weight is 6lb, you're only going to need about 450W [My Maggie flies nicely on 460W at WOT]. With a suitable 15" prop, I'd estimate a motor weighing 200 - 250g, around 600 - 700kv on 4s & 400 - 500kv on 6s. Edited By PatMc on 04/07/2016 15:48:02 Yes, my 1 1/2 strutter is quite lively on around 80W/lb, and I think my Baronette is in the same ballpark. The built-up tail looks to be a good start as per Ton's example. The RCG build compared weights and saved a couple of ounces by replacing the sheet tail surfaces - that's significant with such a short nose. Quote Link to comment Share on other sites More sharing options...
Ton van Munsteren Posted July 4, 2016 Share Posted July 4, 2016 Bob, Its my homemade spinner made from fiberglass over a balsa and foam mold. No the nose is not shorten, for better scale it should be much shorter but then you will need a big motor to have the CG in the right place.. Ton Quote Link to comment Share on other sites More sharing options...
