baza Posted August 15, 2016 Share Posted August 15, 2016 I am halfway through my build.I have one wing partially covered with poly c and i have ran out. RC World does not know when they are getting any more in. Any ideas what I can use to finish it off? It has to be alright to go over the partially covered ploy c wing. Thanks Baz Quote Link to comment Share on other sites More sharing options...
Tony Bennett Posted August 15, 2016 Share Posted August 15, 2016 ronseal diamond hard floor varnish. Quote Link to comment Share on other sites More sharing options...
Dave Hopkin Posted August 15, 2016 Share Posted August 15, 2016 B&Q sell Ronseal Diamond Hard Floor Varnish - the clear version is identical to poly C Quote Link to comment Share on other sites More sharing options...
Martin Harris - Moderator Posted August 15, 2016 Share Posted August 15, 2016 When I saw the title (Ploy C) it did occur to me that you could revert to plan B Quote Link to comment Share on other sites More sharing options...
McG 6969 Posted August 15, 2016 Share Posted August 15, 2016 ... Absolutely Martin, but I would think that 'Ylop A', from Q&B as well, could also work perfectly in this case... ... sorry, leaving the classroom right away... Cheers Chris Quote Link to comment Share on other sites More sharing options...
kc Posted August 15, 2016 Share Posted August 15, 2016 The problem is that Ronseal Diamond Hard Clear is only availble from B&Q in large and expensive quantities! Quote Link to comment Share on other sites More sharing options...
Tony Bennett Posted August 15, 2016 Share Posted August 15, 2016 true but it work out at half the price of poly c, and the amount i get through the large tin is good value. Quote Link to comment Share on other sites More sharing options...
baza Posted August 15, 2016 Author Share Posted August 15, 2016 Thanks for telling me to use ronseal. Dose it still work the same as poly c, can you over paint it when done? Thanks Baz Quote Link to comment Share on other sites More sharing options...
Dave Hopkin Posted August 15, 2016 Share Posted August 15, 2016 Posted by baza on 15/08/2016 20:54:37: Thanks for telling me to use ronseal. Dose it still work the same as poly c, can you over paint it when done? Thanks Baz Its Identical in every respect to Poly-C and if you search hard you can find it in 1L tins rather than the bigger ones Quote Link to comment Share on other sites More sharing options...
