Brushless replacement for 400 geared
John Cooper 1
Hi. Well I have been slightly caught out! The plan is in the post!
It is a Fokker E111 span 1120mm, & weighs 560grms & no prop size is given in the spec but I want to make sure I can get the correct motor before cutting Balsa.
I have another Eindekker 1/8th scale plan by David Boddington 48ins span for .15-.19cu.in with 10x3.5 prop taken off the web but can't get it enlarged to full size & would also need it "electrifying". This is why I have purchased the already electrified plan but then found the specified motor was obsolete.
