iawnski Posted July 15, 2008 Share Posted July 15, 2008 just wondering what you guys out there would say is a decent electric model to choose as a tug ,to say tow a easy glider, ????????? Quote Link to comment Share on other sites More sharing options...
iawnski Posted July 16, 2008 Author Share Posted July 16, 2008 hello anyone here Quote Link to comment Share on other sites More sharing options...
simon barr Posted July 17, 2008 Share Posted July 17, 2008 Hi Iawnski, I'm hereA friend of mine has a Black Horse (I think) Piper Cub which he has electrified, but I'm afraid I don't know the set-up, but I could find out. All I know is that it flies beautifully at around half throttle and has loads of pull at full, so much so that I have being trying to persuade him to put a tow release in it for our CMPro Discus and (still not arrived) Ventus.Simon. Quote Link to comment Share on other sites More sharing options...
simon barr Posted July 17, 2008 Share Posted July 17, 2008 Me again, just seen an advert for the Multiplex Mentor, made from Elapor, has its own dedicated power set and has aerotow option...... maybe worth a lookSimon. Quote Link to comment Share on other sites More sharing options...
iawnski Posted July 17, 2008 Author Share Posted July 17, 2008 hi simon thanks for that will have a look at this cheers Quote Link to comment Share on other sites More sharing options...
Frank Skilbeck Posted July 19, 2008 Share Posted July 19, 2008 I have just finished and test flown an E-Flite DHC Beaver with a Turnigy TR42-50A 700 KV motor, bags of grunt. Quote Link to comment Share on other sites More sharing options...
Former Member Posted July 19, 2008 Share Posted July 19, 2008 [This posting has been removed] Quote Link to comment Share on other sites More sharing options...
Piper Cub Posted July 19, 2008 Share Posted July 19, 2008 A Piper Cub makes a very good tug for aero tow especially since the tail fin has wire stays which not only enhance the scale appearance but also help stop the tow line interferring with the rudder and elevators.There are several good model Piper Cub's out there which are available as electric or can be converted. Hangar 9 do a very good 80 odd inch span cub already fitted with a brushless motor. (You can get the same kit without the motor if you wish to fit your own choice.). Hangar 9 also do an impressive quarter scale cub which can be used as an electric tug.Perkins supply 2 cubs, one a 68 inch intended for glo and another of about quarter scale. I have the 68 inch cub which Im converting to electric. Its virtually ready to fly with all the flying surfaces hinged and pinned with small screws and the best bit is, its only £50!! I've had to take off the motor mount and substitue a few of the horns and clevices because the ones supplied although look fine are not to my liking. If you'd use this as a tug I'd remove the aileron mechanism and substitute with a servo in each wing for better response.If you fancy building from the ground up DB Models do an 82 inch span Cub. Quote Link to comment Share on other sites More sharing options...
James Hindle Posted July 22, 2008 Share Posted July 22, 2008 Hi, I fly an electric tug its a graupner Taxi 2400 with an AXI 5345/16 on 12S lipos so its a bit overkill for what you want but for big models its just the job, if your interested in finding out more about towing or where to put the tow release then take a look at the scale soaring website The video of my tug a cuple of weeks ago is in this threadhttp://www.modelflying.co.uk/forum/forummessages/mps/dt/4/UTN/4056/V/6/SP/ Quote Link to comment Share on other sites More sharing options...
Former Member Posted July 22, 2008 Share Posted July 22, 2008 [This posting has been removed] Quote Link to comment Share on other sites More sharing options...
