Tim Ballinger Posted February 24, 2017 Share Posted February 24, 2017 Hi, Anyone know where I can source an integral fuel tank and engine pod like the one in the photo. The original is over 45 years old and I have just resurrected my big impala of similar vintage and had to clean the grunge out of the tank by breaking the original weld. Cyno has worked for a dozen or so flights but I have had to re glue again today. I can not find anything similar available on line. Any help appreciated. Tim Quote Link to comment Share on other sites More sharing options...
Denis Watkins Posted February 24, 2017 Share Posted February 24, 2017 Built up version Tim, looks adequate Quote Link to comment Share on other sites More sharing options...
GONZO Posted February 24, 2017 Share Posted February 24, 2017 Go electric! Power battery on the base of the power pod, ESC up near motor. Retain original RC batteries in fuselage. Bonus points: no gunge and many climb and glide flights. Quote Link to comment Share on other sites More sharing options...
PatMc Posted February 24, 2017 Share Posted February 24, 2017 As Gonzo but also use a small Rx in the pod using only the throttle control of the Tx, power fed from the ESC's BEC. It means that it doesn't need any physical connection to the pod which can be removed if you want to fly the model as a pure glider. Idea from PhilG the s/c king. Quote Link to comment Share on other sites More sharing options...
ken anderson. Posted February 24, 2017 Share Posted February 24, 2017 hello tim...try a hot screw driver to weld the tank plastic back together.....should work--heat it on the gas ring when her indoors is out......I've done it in the past... ken Anderson..ne...1...... welding dept. Quote Link to comment Share on other sites More sharing options...
Tim Ballinger Posted February 24, 2017 Author Share Posted February 24, 2017 The original was obviously melted together by a hot wire (wire was still in the join) so melting it is a thought. Perhaps use the mini torch fitting on my gas soldering iron. ... and yep I might well go electric in due course; just wanted something quick and easy while I was building other stuff. Did you really mean bind two Rx's to one tx ? Did not know you could do that but sounds an Elegant solution if it works without confusing the tx computer. Tim Quote Link to comment Share on other sites More sharing options...
PatMc Posted February 24, 2017 Share Posted February 24, 2017 Posted by Tim Ballinger on 24/02/2017 17:27:18: Did you really mean bind two Rx's to one tx ? Did not know you could do that but sounds an Elegant solution if it works without confusing the tx computer. Tim I use Frsky gear, there's no problem binding 2 or more Rx's to a single Tx memory if required. IIRC Phil Green uses the set up I described in his Impala. Quote Link to comment Share on other sites More sharing options...
Tim Ballinger Posted March 2, 2017 Author Share Posted March 2, 2017 I will definitely go electric sometime but I'm still rather attached to my old OS10 and without recourse to building a complete new pylon and courtesy of an Italian model shop I have finally found a replacement mount with integral tank. Even better than before because the rear tank is now a screw on item. Does me for now . Thanks for the ideas. Tim Quote Link to comment Share on other sites More sharing options...
Denis Watkins Posted March 2, 2017 Share Posted March 2, 2017 Your patience paid off Tim The .10 will run ages on that tank Quote Link to comment Share on other sites More sharing options...
