Rocker Posted March 16, 2017 Share Posted March 16, 2017 I have been offered a futaba T8J transmitter and two R2008SB receivers very cheap (old club member is packing up model flying).I have a Spectrum DX6i and would love to upgrade to this T8J .He has said to me that the Spectrum servos will fit in the R2008SB receiver and will work fine with the Futaba T8J Radio .I think he is right in what he is saying and most servo will fit in different makes of receivers.Can someone confirm this for me before I buy the radio and receivers.He is like me we are not that knowledgeable when it comes the technical side of model flying Quote Link to comment Share on other sites More sharing options...
Former Member Posted March 16, 2017 Share Posted March 16, 2017 [This posting has been removed] Quote Link to comment Share on other sites More sharing options...
Shaunie Posted March 16, 2017 Share Posted March 16, 2017 I can't imagine there will be a problem. I have a set of Futaba 148s (5) and a HiTec servo running from an AR7000. I also have a set of 3003s running off an orange Rx. Three things to remember, Plug polarisation methods are slightly different, ensure you get the connectors in correctly, if you get it wrong you will do no damage they just won't work. Servo travel is slightly different between the brands, measure control surface travel before and after the change. Only run a supply voltage that does not exceed that of the lowest voltage device. Shaunie. Quote Link to comment Share on other sites More sharing options...
Simon Chaddock Posted March 16, 2017 Share Posted March 16, 2017 I certainly use the same servos on my Spektrum DX6i and my Futaba Tx without even thinking about it. Quote Link to comment Share on other sites More sharing options...
Former Member Posted March 17, 2017 Share Posted March 17, 2017 [This posting has been removed] Quote Link to comment Share on other sites More sharing options...
Peter Miller Posted March 17, 2017 Share Posted March 17, 2017 I have used a huge variety of servos with Futaba, Spektrum and Hitec. These servos have also included Supertec as sold by Perkins up to a while ago and also other independant makes. They all worked. The only thing is that Futaba servos used on othe Receivers have to have the rib down the side trimmed of as other makes of receiver do not have the groove for that rib. Quote Link to comment Share on other sites More sharing options...
