john melia 1 Posted April 25, 2017 Share Posted April 25, 2017 i am foremost a petrol engine guy , but bought a saito 125a , and i'm having a right old time getting a spinner for this engine i bought a plastic spinner with an aluminium back plate which lasted three flights , on the fourth it exploded while using the starter i then bought an aluminium spinner , with the usual single bolt through the centre , but it wont fit as the sujpplied adapter nut will not screw on the crank far enough can someone point me in the right direction for a spinner for this engine , spinner needs to be no bigger than 2.5 inches , and its to go on the seagul glasair , which by the way i maidened last weekend and its a joy to fly Quote Link to comment Share on other sites More sharing options...
ASH. Posted April 25, 2017 Share Posted April 25, 2017 Hi John, in the past I've had to cut the bolt to fit. Call MacGreggor in Reading they should be able to help. Also, Inwoods in Cambridgeshire do domed locking nut for Saitos if it suits.Edited By ASH. on 25/04/2017 09:21:46 Quote Link to comment Share on other sites More sharing options...
Denis Watkins Posted April 25, 2017 Share Posted April 25, 2017 Most spinner nuts are brass John, But Just engines do all manner of steel equivalents To save aluminium shreading, do not go too big, as they will flex when applying the starter I use mostly 2 inch as they are quite sturdy and do not look so bad I appreciate you want bigger than 2.5, but these have to be best fit and can be pinned for strength buy 2 bolts through the backplate Edited By Denis Watkins on 25/04/2017 09:31:06 Quote Link to comment Share on other sites More sharing options...
Gary Manuel Posted April 25, 2017 Share Posted April 25, 2017 John, Depending on the thickness of your propeller, you may need to omit the special Saito Locknut to get the adapter on far enough. The adapter will act as a lock nut of sorts though. Quote Link to comment Share on other sites More sharing options...
jrman Posted April 25, 2017 Share Posted April 25, 2017 Try Tru-Turn in the USA. They're not cheap but they are excellent quality and will do a custom cut on the spinner if you tell them what size and make of prop you intend using. They also do special lock nuts and spinner bolts to suit just about any engine Quote Link to comment Share on other sites More sharing options...
onetenor Posted April 25, 2017 Share Posted April 25, 2017 Would a tube nut help with the reach to the thread Quote Link to comment Share on other sites More sharing options...
Bob Cotsford Posted April 25, 2017 Share Posted April 25, 2017 This is what you want, halfway down the page "Steel Locking Adapter for Large 4 strokes" It replaces the standard locknut. Quote Link to comment Share on other sites More sharing options...
Gary Manuel Posted April 25, 2017 Share Posted April 25, 2017 Good call Bob. I didn't know about them. That's exactly what's needed. May be buying one or two of them myself (Saito 82 and 150 with similar issues). Quote Link to comment Share on other sites More sharing options...
Bob Cotsford Posted April 25, 2017 Share Posted April 25, 2017 I must admit that I've made my own by putting a standard adaptor in the pillar drill and using a file to adjust the profile of the blunt end, then putting a slot down it with a hacksaw to allow the internal thread at the end to compress onto the prop shaft. Seems to work ok. Quote Link to comment Share on other sites More sharing options...
Rich too Posted April 25, 2017 Share Posted April 25, 2017 I agree, cut the bolt to length. I rarely find the bolt is the correct length or size. Start it by hand? Quote Link to comment Share on other sites More sharing options...
john melia 1 Posted April 25, 2017 Author Share Posted April 25, 2017 Thanks Bob just ordered one of those from JE , i also asked them about a petrol conversion , and they said a lot of people have converted the saito to petrol , with no significant loss of power I will be converting at the end of the summer with the kit JE supply Quote Link to comment Share on other sites More sharing options...
