Paul C. Posted May 8, 2017 Share Posted May 8, 2017 Great model, great video , look forward to seeing it at the shows this year 👍 Paul. Quote Link to comment Share on other sites More sharing options...
Dwain Dibley. Posted May 8, 2017 Share Posted May 8, 2017 I will also be looking forward to seeing You and the model at the shows Robbie, and another natter with the "old fella", I still need to take him up on the invite from 2 years back. Bostin model, Bostin maiden, and all round, jolly exiting video. Thanks for Posting. D.D........ OIC ...DY9....just round the corner Dept !! Quote Link to comment Share on other sites More sharing options...
Robbie Skipton - Skip Model Designs Posted May 8, 2017 Author Share Posted May 8, 2017 Thanks guys. Look forward to hopefully seeing you at the shows.. Come over and say hello... I dont Bite Honest Dwain, Any time you want Quote Link to comment Share on other sites More sharing options...
john stones 1 - Moderator Posted May 8, 2017 Share Posted May 8, 2017 Not seen the video, he's rubbish at links Quote Link to comment Share on other sites More sharing options...
MattyB Posted May 8, 2017 Share Posted May 8, 2017 Here you go... Although I personally wouldn't do it myself, I can't see anything fundamentally unsafe in the roll that Robbie did shortly after takeoff. Yes I suppose he could have had a structural failure or discovered a snafu (reversed ailerons etc.) at that point, but if an issue had occured that brought the model down it would have been well away from spectators. I would have done a few nerve steadying passes first, but at some point with a model like this you have to start putting it through manoeuvres - there's no real reason that can't be on the first flight if you are happy with the trim. Edited By MattyB on 08/05/2017 17:41:02 Quote Link to comment Share on other sites More sharing options...
Former Member Posted May 8, 2017 Share Posted May 8, 2017 [This posting has been removed] Quote Link to comment Share on other sites More sharing options...
john stones 1 - Moderator Posted May 8, 2017 Share Posted May 8, 2017 Cheers Matty Can't see much to get worked up about myself, some mild aero's n a roll after take off. Love the colour scheme Robbie John Quote Link to comment Share on other sites More sharing options...
MattyB Posted May 8, 2017 Share Posted May 8, 2017 On a different topic I was quite surprised how much this model got thrown about in the wind considering it's large size. I guess it is probably quite lightly loaded and obviously it's very draggy with a lot of front and side area. Certainly looked a bit of a handful on landing, especially the second flight. Quote Link to comment Share on other sites More sharing options...
Robbie Skipton - Skip Model Designs Posted May 8, 2017 Author Share Posted May 8, 2017 It weighs only 109lbs with fuel( which is approx 25 to 30lbs lighter than the blackone).And it is a massive wing and fuaelage.The second flight was cut short for 2 reasons. The wind really picked up (25mph) which i deemed unsafe to fly and then the bloody spinner came loose.. hence the rattle. Quote Link to comment Share on other sites More sharing options...
MattyB Posted May 8, 2017 Share Posted May 8, 2017 Maybe you need to ballast it for high winds like a sloper... PS - When converting 109lbs to kg (yup, I'm a child of the metric age) Google helpfully informed me that this model r model weighs exactly the same as one of the worlds most untalented celebrities...! Edited By MattyB on 08/05/2017 23:11:41 Quote Link to comment Share on other sites More sharing options...
MattyB Posted May 8, 2017 Share Posted May 8, 2017 Ooops, forgot the link in the above post... Quote Link to comment Share on other sites More sharing options...
Robbie Skipton - Skip Model Designs Posted May 9, 2017 Author Share Posted May 9, 2017 Mattyb... you must admire her to know that .Dont know if its sad to know that or just obsessive lol Quote Link to comment Share on other sites More sharing options...
Robbie Skipton - Skip Model Designs Posted June 29, 2017 Author Share Posted June 29, 2017 Sorry, Just read this post again.. Here are all the specs of my models to date 40% Pitts Challenger 2 Specifications Weight – From 14KG Wing Span – 2.4 m Length – 2.6m Servos – 8 x 15kg Digital Servos 2 x Digital Servos for throttle and choak Recommended Engine:- DA 100, DA120 , DLE120, ZDZ120, DA150 55% Pitts Challenger 2 Specifications Weight – 30Kg Wing Span – 3.0 m Length – 3.1m Servos – 16x 25kg Digital Servos 2 x Digital Servos for throttle and choak Recommended Engine:- ZDZ 210, ZDZ250 , 3W 224 B4, DLE 222 And of course this one 65% Pitts Challenger 2 Specifications Weight – 44 – 55kg ( 97 Lbs to 110 LBS) Wing Span – 3.5 m Length – 3.7m ( Detachable Rudder) Servos – 17x 25kg Digital Servos 2 x Digital Servos for throttle and choak Recommended Engine:- ZDZ 420, ZDZ500, ZDZ360, 3W 342, 3W684 All 3 Challengers will be at Cosford on our store.. The 55% and 65% will be flying.. The 40% will be a static Edited By Robbie Skipton - Skip Model Designs on 29/06/2017 12:11:53 Quote Link to comment Share on other sites More sharing options...
Rich too Posted June 30, 2017 Share Posted June 30, 2017 I like the detail in your models Robbie some large models I see at the shows look cartoon like. Your 40% Pitts is on my wish list Quote Link to comment Share on other sites More sharing options...
