Tom Thomas Posted October 22, 2017 Share Posted October 22, 2017 As per title I Maidened my Wildthing today. It didn't go very well really, it doesn't seem to penetrate well? I took a couple of weights with me and it seemed a bit better but I think it still needs more although I did balance it and reflexed it as advised. A couple of very short launch vids below, be great to hear what people think. https://youtu.be/2Dq8cpkbu_k https://youtu.be/XK899MycVXg https://youtu.be/1x_hDWnPxvw Quote Link to comment Share on other sites More sharing options...
Tom Thomas Posted October 22, 2017 Author Share Posted October 22, 2017 Could a mod be very kind and sort my links as this iPad is winding me up! Many thanks Quote Link to comment Share on other sites More sharing options...
Stevo Posted October 22, 2017 Share Posted October 22, 2017 Sorted!!!! Edited By Stevo on 22/10/2017 18:28:03 Quote Link to comment Share on other sites More sharing options...
PatMc Posted October 22, 2017 Share Posted October 22, 2017 It just looks like there's too much up elevator - i.e. reflex - or it's tail heavy. If the cg at the recommended position I'd reduce the reflex in increments & try over & over until it flies. It's a bouncy model so it'll take a lot of abuse. I have the first generation Wildthing, it has a fair margin between flying at slow speed close to stall then increasing the down elevator to much faster speed but maintaining height to pretty much the same degree at both extremes. PS The first & third were bad launches. Always launch with the nose pointing slightly down so that the model gains speed before trying to gain height. It should still climb even with the nose slightly down, if it doesn't it would sink anyway. Edited By PatMc on 22/10/2017 18:37:25 Quote Link to comment Share on other sites More sharing options...
onetenor Posted October 22, 2017 Share Posted October 22, 2017 Posted by Tom Thomas on 22/10/2017 18:01:49: As per title I Maidened my Wildthing today. It didn't go very well really, it doesn't seem to penetrate well? I took a couple of weights with me and it seemed a bit better but I think it still needs more although I did balance it and reflexed it as advised. A couple of very short launch vids below, be great to hear what people think. https://youtu.be/2Dq8cpkbu_k https://youtu.be/XK899MycVXg https://youtu.be/1x_hDWnPxvw LINKS SHOW 404 not found Quote Link to comment Share on other sites More sharing options...
PatMc Posted October 22, 2017 Share Posted October 22, 2017 Posted by onetenor on 22/10/2017 18:51:50: LINKS SHOW 404 not found I had no problem but they now can be seen directly via Stevo's post anyway. Quote Link to comment Share on other sites More sharing options...
Tom Thomas Posted October 22, 2017 Author Share Posted October 22, 2017 Huge thanks stevo! Hi pat, I think it needs more nose weight and fiddling with the reflex as you suggest. Also thanks for the launching advice Quote Link to comment Share on other sites More sharing options...
Piers Bowlan Posted October 22, 2017 Share Posted October 22, 2017 Pat said reduce the reflex (I concur). Check the c of g is in the right place according to the instructions. Flying wings are very sensitive in this regard. Too far forward and it won't fly well, too far back and it won't fly at all! Quote Link to comment Share on other sites More sharing options...
cymaz Posted October 22, 2017 Share Posted October 22, 2017 Looking at your WT on the second video, as it is sitting on the ground, after landing, there is far too much reflex. Reduce and have another go. Good luck. Edited By cymaz on 22/10/2017 22:41:09 Quote Link to comment Share on other sites More sharing options...
Harry Twist Posted October 22, 2017 Share Posted October 22, 2017 Hi I would agree with all the above ref cog and reducing the reflex and the need for careful launching (nose horizontal or even better, slightly down) - I know with my Wildthing - one click of up or down makes a difference, there is definitely a sweet spot! Also, respectfully - not sure if you were just test gliding or trying to slope soar - to get the model to soar continually, I would suggest a much steeper slope is needed - in the footage there seems to be lots of horizontal breeze but not much upgoing air to provide you with the lift you need to sustain flight. Maybe try a different site? (just trying to be helpful). They are tough models that will take a knock or two and are great fun to fly once sorted out! Hope you enjoy it. Quote Link to comment Share on other sites More sharing options...
PatMc Posted October 22, 2017 Share Posted October 22, 2017 Posted by Harry Twist on 22/10/2017 23:48:33: Also, respectfully - not sure if you were just test gliding or trying to slope soar - to get the model to soar continually, I would suggest a much steeper slope is needed - in the footage there seems to be lots of horizontal breeze but not much upgoing air to provide you with the lift you need to sustain flight. Maybe try a different site? (just trying to be helpful). I wondered about the slope gradient too but thought the camera angle might making it look flatter than it really is. Quote Link to comment Share on other sites More sharing options...
Tom Thomas Posted October 23, 2017 Author Share Posted October 23, 2017 Thankyou all so much for your advice it's much appreciated Funnily enough I literally just said to my wife that maybe the slope isn't steep enough, it gets a lot steeper as it goes along but it is a yomp bit I will try further along next time. I'll also add a bit more nose weight and play with the reflex, it's frustrating I don't still have my dx6i as clicking trim is much better than using the sliders on this Saturn transmitter. I have a Futaba T6k V2 coming for Christmas that will probably help a lot. Quote Link to comment Share on other sites More sharing options...
