Tom Thomas Posted October 25, 2017 Share Posted October 25, 2017 hey all, I bought a Dx5e dirt cheap on eBay to fiddle with. If I remember correctly it's seller said it didn't work as he had tried to change the mode. It's mode 2 and the casing is a mode 2 case, so maybe he tried it and then tried to swap back? His soldering is not the best, but I wanted to pick the collective brains of you talented chaps. In the pictures below does anybody spot any wiring in the wrong place? It powers up ok but I have to wait to fully test it as I don't have a compatible rx. I know the blue and red wires are off and looking at images on the net I can see where they go. Anyway some pics Quote Link to comment Share on other sites More sharing options...
Former Member Posted October 25, 2017 Share Posted October 25, 2017 [This posting has been removed] Quote Link to comment Share on other sites More sharing options...
Dwain Dibley. Posted October 25, 2017 Share Posted October 25, 2017 Have you got a club mate who has a working one ???? Will he let you take the back off ??? Just a thought. D.D Quote Link to comment Share on other sites More sharing options...
Denis Watkins Posted October 25, 2017 Share Posted October 25, 2017 A simple start would be to test each newly soldered cable from its source, for continuity To the pot connectors where they leave the pot, back to the board connectors Without power pack in the Tx It is unlikely the work went any further than the gimbals Quote Link to comment Share on other sites More sharing options...
Tom Thomas Posted October 26, 2017 Author Share Posted October 26, 2017 No Dwain, I'm not in a club...... I be a loner Thanks for the details Percy Will have a look Denis, but I don't know what I'm looking at lol Quote Link to comment Share on other sites More sharing options...
Denis Watkins Posted October 26, 2017 Share Posted October 26, 2017 OK Tom, in your picture, we can see the back of the stick pivots, the gimbals These are connected to the transmitter at 4 points, 2 each side, by pots, potentiometers Which are cylinder shaped variable resistors which produce our proportional control eventually. The previous owner would only have soldered wires to these pots, 3 connections each One or more of these soldered joints could be "dry", ie they look soldered, but are not electrically connected, " dry" With a simple tester, these connections could be checked and resoldered Edited By Denis Watkins on 26/10/2017 09:16:55 Quote Link to comment Share on other sites More sharing options...
Former Member Posted October 26, 2017 Share Posted October 26, 2017 [This posting has been removed] Quote Link to comment Share on other sites More sharing options...
Denis Watkins Posted October 26, 2017 Share Posted October 26, 2017 Tom, I cannot copy your picture But left hand gimbal, bottom pot A blue wire looks disconnected, as well as the red Have a close look Quote Link to comment Share on other sites More sharing options...
John Robertson 3 Posted October 26, 2017 Share Posted October 26, 2017 The "hidden switch" is mentioned at 3m 49s in this video on YouTube: https://www.youtube.com/watch?v=oRycayn9hXk I'm a "loner" too. Quote Link to comment Share on other sites More sharing options...
Denis Watkins Posted October 26, 2017 Share Posted October 26, 2017 Thanks Steve That blue wire is clearly not connected Quote Link to comment Share on other sites More sharing options...
David Ovenden Posted October 26, 2017 Share Posted October 26, 2017 Tom told us he knew the red and blue wires were disconected in his original post. Quote Link to comment Share on other sites More sharing options...
Tom Thomas Posted October 26, 2017 Author Share Posted October 26, 2017 Posted by David Ovenden on 26/10/2017 21:58:39: Tom told us he knew the red and blue wires were disconected in his original post. Thanks David i did I'd not Thought of dry solder Denis? Thanks for the tip. Thanks for the thanks for the hidden switch Steve and john. I have resoldered the connections and await the delivery of an rx to test it with. I had noticed the antenna, it was trapped in the casing by the look of it, I will replace it Steve Quote Link to comment Share on other sites More sharing options...
John Robertson 3 Posted October 27, 2017 Share Posted October 27, 2017 Want Expo on the DX5e? I found a thread on, I think, RCGroups and found a document relating to the eFlite UMX Taxi. It had a passage mentioning the setting Expo on both the DX4e and DX5e. Not mentioned in the Spektrum handbooks (I have 1 of DX4e and 2 off DX5e [one of which is set up for buddy-boxing]). For the DX5e (Modes 1 & 2), to activate Expo: 1] Hold the aileron trim switch to the right when powering on theTtx. 2] Release the aileron trim switch after a series of ascending tones to confirm that Expo is activated. To deactivate Expo: 1] Hold the aileron trim switch to the left when powering on the Tx. 2] Release the aileron trim switch after a series of descending tones to confirm that Expo is deactivated. The DX4e, with its mechanical trims (which I must admit I rather like as one can see exactly what trim level is engaged!), has a different procedure. I have had well over 2 hours flying yesterday evening and this morning with the DX5e set up with Expo and I liked it - that reduced central movement helped in quite gusty spells. Edited By John Robertson 3 on 27/10/2017 13:25:21 Quote Link to comment Share on other sites More sharing options...
Tom Thomas Posted October 27, 2017 Author Share Posted October 27, 2017 Very interesting vid that, I didn't watch it all but I'm assuming you would need to swap or adjust the throttle spring? Many thanks for the expo tip john! I wonder if it was built in on purpose ?. Quote Link to comment Share on other sites More sharing options...
Tom Thomas Posted November 2, 2017 Author Share Posted November 2, 2017 So, my orange rx arrived and I got it to bind to the tx (even with its dodgy Ariel) . It seems that both sticks respond to up and down movement, but they don't respond to side to side movement. So I resoldered the connections to the rudder and aileron "pots" is it? But still nothing. I have noticed some chalky like mess on some bits of the circuit board, would this indicate burnt out components? Quote Link to comment Share on other sites More sharing options...
Denis Watkins Posted November 2, 2017 Share Posted November 2, 2017 Side to side stick movement is detected by the pots at the bottom of the gimbals The round things The wires on these are definitely spread in the picture and have been disturbed Get your magnifying glass on these Quote Link to comment Share on other sites More sharing options...
Denis Watkins Posted November 2, 2017 Share Posted November 2, 2017 Directed, not detected, apologies Quote Link to comment Share on other sites More sharing options...
Tom Thomas Posted November 3, 2017 Author Share Posted November 3, 2017 Posted by Denis Watkins on 02/11/2017 20:15:50: Side to side stick movement is detected by the pots at the bottom of the gimbals The round things The wires on these are definitely spread in the picture and have been disturbed Get your magnifying glass on these Hi Denis, yes that's the ones I resoldered. Quote Link to comment Share on other sites More sharing options...
Tom Thomas Posted November 3, 2017 Author Share Posted November 3, 2017 Well, I removed the aileron pot and soldered it to the elevator wires (that previously worked) and got not a twitch. I'm going to assume that whatever the previous owner did damaged the pot Before I did that I noticed that the aileron trim contacts were soldered together see pic I compared it to the rudder trim and saw that it was not meant to be I did my best to remove the excess solder but it still wouldn't work. So I took the aileron pot apart and the only damage I could see were possible scorch marks from the solder heat maybe? Decide for yourself. Anyway, I've given up now but it kept me from shouting at trees for a while...... Quote Link to comment Share on other sites More sharing options...
Denis Watkins Posted November 3, 2017 Share Posted November 3, 2017 Go the extra mile Tom, and replace those pots You can do it Quote Link to comment Share on other sites More sharing options...
Geoff S Posted November 3, 2017 Share Posted November 3, 2017 I don't think that the excessive solder on the trim contacts would be a problem as the resistors are connected together by the circuit board anyway - perhaps whoever added the extra solder thought the track was cracked? If you have a pot of any sort handy you could try bodging one in to see if it had any effect - I've no real idea what value but I'd try a 1k for a start. It's worth persevering IMO because a) it'll stop you shouting at trees and b) you've nothing to lose and it's interesting. It's interesting that both rudder and aileron controls don't work so probably something common to both horizontal pots, perhaps. Geoff PS As usual I just thought of something after I'd posted Measure the value of the vertical pots to see what to use to try a new one. They're almost certainly the same value. Edited By Geoff Sleath on 03/11/2017 10:55:31 Quote Link to comment Share on other sites More sharing options...
