Stuart Z Posted March 9, 2018 Share Posted March 9, 2018 Hi folks I would like your advice. When it comes to cutting canopies free of their flashing the basic shape can be done by rubbing on abrasive on a flat board. But, when it comes to more complex cutting, say a Spitfire canopy with two levels at the back and a 45 ish degree slope to the front, sanding is not going to be easy. Looking for your thoughts, small scissors come to mind, but is that the best way and avoid splitting? Thanks in anticipation. S Quote Link to comment Share on other sites More sharing options...
Ron Gray Posted March 9, 2018 Share Posted March 9, 2018 i use scissors to do a rough cut and then finish off with a razor plane / permagrit block or Dremel sanding drum running at low revs (prevents plastic melting). Quote Link to comment Share on other sites More sharing options...
Bob Cotsford Posted March 9, 2018 Share Posted March 9, 2018 Where you have a step in an edge drill a small hole (1/16", 1.5mm) in the corner so that you cut to the hole. This helps to stop it splitting from the corner. Quote Link to comment Share on other sites More sharing options...
Jon Laughton Posted March 9, 2018 Share Posted March 9, 2018 Yes to all the above....best to use curved scissors and have some in different sizes Quote Link to comment Share on other sites More sharing options...
Stuart Z Posted March 9, 2018 Author Share Posted March 9, 2018 Thanks guys I’ll be getting some fine straight and curved scissors this weekend! Already have the dremel sanders and can give that a go! Thanks again! S Quote Link to comment Share on other sites More sharing options...
Cuban8 Posted March 9, 2018 Share Posted March 9, 2018 I find that scoring with a sharp pointed scalpel and then snapping off the waste works as well. Different methods for various canopy shapes, obviously. Quote Link to comment Share on other sites More sharing options...
Stuart Z Posted March 9, 2018 Author Share Posted March 9, 2018 Thanks C8 All ideas welcome. Fed up with ragged edges and splits so these ideas / tools now taken on board. S Quote Link to comment Share on other sites More sharing options...
Steven S Posted March 9, 2018 Share Posted March 9, 2018 After cutting the canopy to its rough final shape I plan on wrapping some emery cloth over the fuselage [grit side up] and sliding the canopy back and forth over it to the final shape on my Grumpy Tiger Cub. I saw a picture of it recently and it seems a good idea to try. I'll find out soon enough. Quote Link to comment Share on other sites More sharing options...
Ron Gray Posted March 11, 2018 Share Posted March 11, 2018 Further to my post above, I use these as they offer different sizes of sanding drums for the Dremel **LINK** Quote Link to comment Share on other sites More sharing options...
Steven S Posted March 21, 2018 Share Posted March 21, 2018 This is what I was trying to describe in my earlier post. Quote Link to comment Share on other sites More sharing options...
Stuart Z Posted March 21, 2018 Author Share Posted March 21, 2018 Thanks Steven, Looks a good idea to get the fuselage profile. S Quote Link to comment Share on other sites More sharing options...
