ESC only working with throttle trim fully down
Hi,
Tried to fly my Aether yesterday but no motor, no beep from ESC. Removed motor today and still not working so I disconnected at and for some unknown reason I decided to set motor trim as low as it will go and now it seems to work. The ESC is a hobbyking 100a SBEC but I do not know the motor, the transmitter is a DX6i but I have never had to do this before, does anyone have any ideas or come across this before?
Hi Peter,
it sounds as if the throttle calibration (stored in the ESC) has drifted a little. The ESC isn't arming because the throttle won't go low enough to register as closed: a safety feature of the ESC.
I've seen this, and I'm not absolutely sure why it happens: high temperatures, perhaps?
The solution is to reteach the ESC the throttle range. I'm not familiar with your particular ESC but it should have programming instructions. It usually involves starting the ESC with the throttle stick at the top to enter programming mode...
" I have never had to do this before, does anyone have any ideas or come across this before?"
Check the ESC manual, you will likely have an option to program the throttle range.
If you've triggered that option accidentally then the ESC may now have got the wrong end of the stick, so to speak.
In my experience (with a DX6i) it is common and with many ESC essential that the throttle trim is set to minimum.
I actually set up the ESC throttle range like this so it becomes part of the before connecting the battery check - "throttle fully closed" or it will just beep and not arm.
To my way of thinking setting "throttle cut" is irrelevant with electric - just fully close the throttle. wink 2
