Nigel Hawes 30" Tucano advice.
Hi Clive I built one earlier this year, an absolute gem.
The artical is not the best, but is states 8mm movement on all surfaces to start with and adjust to your own requirements.
You don’t need that much believe me, but it can be a bit quick. Have fun, I do. Just started building another one.
Hi Clive
I would add, make sure you buy the canopy from Vortex vacforms, I think that’s the name. I cracked the first one I bought, so made the one in the picture by shaping old balsa glued together and then hollowing out from the inside. It’s worked ok, but a bit heavy. I’ve just received 2 new once’s from this company.
Tom
