dirk tinck Posted October 25, 2019 Author Share Posted October 25, 2019 I'm letting this dry out for some day's for easyer sanding. Meanwhile i'm starting on the motor-hatch. First get the right position sorted ,not easy when you don't know the right plae for the motor.... Quote Link to comment Share on other sites More sharing options...
dirk tinck Posted October 25, 2019 Author Share Posted October 25, 2019 Before i cut it out ,i'm reinforcing the hatch itself with some foam not to disturb the form.Before i glue the foam on the hatch i'm taping it so that i can remove it with ease. Quote Link to comment Share on other sites More sharing options...
dirk tinck Posted October 25, 2019 Author Share Posted October 25, 2019 Finally i'm glueing a piece of mdf board on the foam to strenghten the combo Quote Link to comment Share on other sites More sharing options...
dirk tinck Posted October 25, 2019 Author Share Posted October 25, 2019 Everything ready for the cut ? Quote Link to comment Share on other sites More sharing options...
dirk tinck Posted October 25, 2019 Author Share Posted October 25, 2019 Time to prepare the hatch and the opening in the fuse for later moulding by glueing some casting material arround the edges Quote Link to comment Share on other sites More sharing options...
Stephen Jones Posted October 25, 2019 Share Posted October 25, 2019 That`s cleaver Dirk. Steve. Quote Link to comment Share on other sites More sharing options...
dirk tinck Posted October 25, 2019 Author Share Posted October 25, 2019 Quote Link to comment Share on other sites More sharing options...
dirk tinck Posted October 25, 2019 Author Share Posted October 25, 2019 And the result : Quote Link to comment Share on other sites More sharing options...
Martyn K Posted October 25, 2019 Share Posted October 25, 2019 Hi Dirk Still following along. how does the casting material work? What is it? Martyn Quote Link to comment Share on other sites More sharing options...
dirk tinck Posted October 25, 2019 Author Share Posted October 25, 2019 Next day's i will do thesame for the front hatch to be able to reach the front retract. Need a drink now ....cheers ! Quote Link to comment Share on other sites More sharing options...
dirk tinck Posted October 25, 2019 Author Share Posted October 25, 2019 Hi Martyn ,thanks for following. The casting material is in fact ''ply'' with both sides laminated with some sort of shiny layer. It's thesame as concrete casting material but not so thick.I use the 4 mm version.It is sold in plates 1.25M X2.5M and relatively cheap. I think it's 20€ per plate. The great advantage is that when you don't sand it , the epoxy dusn't stick to it !!and you can polish it like a mirror. Hope this helps ?? Greetz , Dirk Quote Link to comment Share on other sites More sharing options...
dirk tinck Posted October 25, 2019 Author Share Posted October 25, 2019 I cut it with a disc grinder to avoid the edges getting raffled,It stinks then but hey !I do have clean edges !! Quote Link to comment Share on other sites More sharing options...
dirk tinck Posted November 2, 2019 Author Share Posted November 2, 2019 As promissed a series of pictures taken during the build of the fuse-plug back in 2016.I didn't have a hobby space then and had to use all the availeble space i could find so don't judge anything other than aircraft parts please Quote Link to comment Share on other sites More sharing options...
dirk tinck Posted November 2, 2019 Author Share Posted November 2, 2019 Quote Link to comment Share on other sites More sharing options...
dirk tinck Posted November 10, 2019 Author Share Posted November 10, 2019 Hi all,hope i didn't bore you with the ''the making of'' the fuselage plug in 2016. Meanwhile the rudder is primered and drying, and the front hatch is made the same way i did the motor hatch.In the background you see the tail cone also primered.This part also comes from the PSS moulds. Quote Link to comment Share on other sites More sharing options...
dirk tinck Posted November 10, 2019 Author Share Posted November 10, 2019 First drawn the hatch on the fuse as scale like as possible.The real fouga needs this opening to refill the guns in the nose. Quote Link to comment Share on other sites More sharing options...
