Geoff Gardiner Posted August 22, 2019 Author Share Posted August 22, 2019 Thanks Nik. I went into a bit more detail in my Spitfire build log here. Pages 6-7. Hope that helps. Quote Link to comment Share on other sites More sharing options...
Geoff Gardiner Posted August 22, 2019 Author Share Posted August 22, 2019 Hi Doug I have sent you a PM. Quote Link to comment Share on other sites More sharing options...
Geoff Gardiner Posted September 3, 2019 Author Share Posted September 3, 2019 Designed and 3d printed some retract covers. More later... Quote Link to comment Share on other sites More sharing options...
Geoff Gardiner Posted October 3, 2019 Author Share Posted October 3, 2019 Bit more work done on the canopy: More later... Quote Link to comment Share on other sites More sharing options...
Nik Harrison Posted October 4, 2019 Share Posted October 4, 2019 Impressive work. Very nice. Quote Link to comment Share on other sites More sharing options...
Nigel R Posted October 4, 2019 Share Posted October 4, 2019 That looks very smart, great work. Quote Link to comment Share on other sites More sharing options...
adrian garnham Posted October 6, 2019 Share Posted October 6, 2019 I am a new member and this is my first post !! This build log and your craftsmanship is second to none , I am about to purchase the harvard plan from Tony Nijhaus designs. Can you tell me what electric setup you have used and what retracts you ended up purchasing ? Quote Link to comment Share on other sites More sharing options...
Douglas Groutage Posted October 6, 2019 Share Posted October 6, 2019 Looking good Geoff! Quote Link to comment Share on other sites More sharing options...
Geoff Gardiner Posted October 6, 2019 Author Share Posted October 6, 2019 Thanks gents. Nearly there! I am fitting all the electric gubbins now. I am using a failover switch for (LiFe) battery redundancy on the receiver. I needed to make a mount, using my 3D printer, so that it will fit in the battery compartment : Welcome to the forum Adrian. I will detail my electric setup in my next post. More later. Geoff... Quote Link to comment Share on other sites More sharing options...
Geoff Gardiner Posted October 7, 2019 Author Share Posted October 7, 2019 Hi Doug. I have just emailed you those files. Sorry it took so long. Quote Link to comment Share on other sites More sharing options...
Douglas Groutage Posted October 7, 2019 Share Posted October 7, 2019 Posted by Geoff Gardiner on 07/10/2019 11:57:07: Hi Doug. I have just emailed you those files. Sorry it took so long. No issues Geoff. I’m no where near ready to print them. But thanks I did receive them! Your build log is a good reference for me. It’s been invaluable to double check what I am doing. Quote Link to comment Share on other sites More sharing options...
Geoff Gardiner Posted October 7, 2019 Author Share Posted October 7, 2019 Hi Adrian. These are the electric bits that i am using: retracts here Motor here ESC here Battery - 5S 5000mah Turnigy Graphene Hope that helps. Geoff... Quote Link to comment Share on other sites More sharing options...
adrian garnham Posted October 8, 2019 Share Posted October 8, 2019 Thanks Geoff I've ordered the plans .... can't wait to get started. Quote Link to comment Share on other sites More sharing options...
Geoff Gardiner Posted October 8, 2019 Author Share Posted October 8, 2019 That's great Adrian, I think you will enjoy the build. Are you going to do a build blog? Geoff... Quote Link to comment Share on other sites More sharing options...
adrian garnham Posted October 8, 2019 Share Posted October 8, 2019 I would like to do a build log but will see how it goes Quote Link to comment Share on other sites More sharing options...
Geoff Gardiner Posted October 8, 2019 Author Share Posted October 8, 2019 Bit more done today: Fixed the wasp engine onto its mounts Next, the bit I've been dreading - test the CofG... Having moved the ESC and receiver batteries as far forward as they could go, it needed 120g of stick on weights to achieve the required CofG. As feared, it has come out a tad on the heavy side - 4.5kg including the flight battery. The last thing to do is test the power and select a suitable prop. More later. Geoff... Quote Link to comment Share on other sites More sharing options...
Douglas Groutage Posted October 8, 2019 Share Posted October 8, 2019 Use a 6S a little heavier? The pilot needs to gain weight? How much will the prop increase the leverage of CoG? Doug Quote Link to comment Share on other sites More sharing options...
Geoff Gardiner Posted October 9, 2019 Author Share Posted October 9, 2019 Power testing today: 14x8 prop gives 1700W & 90A 13x8 prop gives 1550W & 83A 12x8 prop gives 1250W & 65A These readings were at max throttle. More later... Quote Link to comment Share on other sites More sharing options...
Geoff Gardiner Posted October 10, 2019 Author Share Posted October 10, 2019 All props in my previous post were APC props Tested a couple more props today: 13x7 JXF (I think this might be an i.c. prop) 1180W & 60A 13x8.5 Master Airscrew Electric 1500W & 78A Quote Link to comment Share on other sites More sharing options...
Geoff Gardiner Posted October 14, 2019 Author Share Posted October 14, 2019 Tis done! Raining outside so took some snaps inside: Flight report when weather improves... Quote Link to comment Share on other sites More sharing options...
SR 71 Posted October 14, 2019 Share Posted October 14, 2019 very nice Geoff, what make is the switch you used, Power Box Quote Link to comment Share on other sites More sharing options...
adrian garnham Posted October 14, 2019 Share Posted October 14, 2019 Looks great. If mine turns out half as good I'll be well chuffed. All the wood and electrical stuff has arrived just waiting for the plans .... BTW what prop have you decided on ? Quote Link to comment Share on other sites More sharing options...
Geoff Gardiner Posted October 14, 2019 Author Share Posted October 14, 2019 Thanks gents. SR71 - The switch is the Hobbyking version (failover switch), similar to the Power Box one. Adrian - Jury still out on that. I want to get hold of a 13x6 to test before I decide. Quote Link to comment Share on other sites More sharing options...
