nigel newby Posted October 15, 2018 Share Posted October 15, 2018 Hi all, just getting back into modelling. I thought that I would try a simulator. I have FPS which uses a e sky 0905a 4 channel imitation radio control box. FPS is very limited I have found. Most of the time I cannot use a rudder as it does not work. I have down loaded Picasim, but cannot get that to respond to my controller. I fancy Pheonix, but please what is a dongle, and what does it do. I have seen stuff advertised, but I do not know if it has a dongle. I also have two 35mhz futaba controlers. One is a fp-t5n and the other is a t6exap. I believe that these can be used with a lead.. I have seen dongles advertised but how do they work. I am just trying to save muself money and disappointment. Grumpy old git Nigel Quote Link to comment Share on other sites More sharing options...
Denis Watkins Posted October 15, 2018 Share Posted October 15, 2018 Nigel, the Dongle electronically qualify's you as the purchaser, and that you can access the software Phoenix is the business, and needs a cable with the dongle attached, to work The sticks on a transmitter, and the switches, are all used by the software, as the Tx is not transmitting So most Tx with a cable to fit will work There is a list of Transmitters on Phoenix online Edited By Denis Watkins on 15/10/2018 20:59:20 Quote Link to comment Share on other sites More sharing options...
Biggles' Elder Brother - Moderator Posted October 15, 2018 Share Posted October 15, 2018 Hi Nigel, You might find it very difficult to buy Pheonix. It was produced by a German company and distributed by Horizon. When Horizon sort of went AWOL Pheonix seems to have disapeared! You can get second hand versions - and loads of copies (very much caveat emptor territory that) but a warrented new version from an established model shop or on line vendor, I think you might struggle. BEB Quote Link to comment Share on other sites More sharing options...
nigel newby Posted October 15, 2018 Author Share Posted October 15, 2018 Thanks for that chaps. I was not sure what the "dongle" was, but now I know, I know what to look for. I have seen a second hand one so mi=ght buy that. Not quite so grumpy Nigel Quote Link to comment Share on other sites More sharing options...
Dave Cooper 3 Posted October 15, 2018 Share Posted October 15, 2018 Hi again Nigel I use Phoenix - a really great sim'. I just dedicate one model in the Tx memory to it and it's all there including all the 'tweaks' I've made along the way. I needed a special lead for the PC : USB > Buddy box socket on the rear of the Tx casing..The model shop supplied all this and I think it was about £80 all in. The shop was on the south coast, near Poole, I think (lost the receipt years ago !). Phoenix does seem to have gone a bit 'Heli' of late, but, there are still a lot of fixed wing models to choose from (100+ ?) . Also, it will tell you if there are any new models (or, it used to) when you log on. The purchase option on their website points you to Horizon (UK still going ?) and there's a Support option too - email maybe...Not too many gliders but the ones they have (eg the Fox aerobatic) are quite good ! Worth persevering with I should have thought, Dave Quote Link to comment Share on other sites More sharing options...
nigel newby Posted October 16, 2018 Author Share Posted October 16, 2018 I am off to poole this weekend so will have a look see Quote Link to comment Share on other sites More sharing options...
Dave Hess Posted October 16, 2018 Share Posted October 16, 2018 I heard that Phoenix have packed it in. You'd probably be better off going with Realflight. Quote Link to comment Share on other sites More sharing options...
Former Member Posted October 16, 2018 Share Posted October 16, 2018 [This posting has been removed] Quote Link to comment Share on other sites More sharing options...
nigel newby Posted October 16, 2018 Author Share Posted October 16, 2018 I have just downloaded clearview , but cannot get it to do anything.PS I am not to hot on computers. But nothing works. No planes, flying fields. Nothing. What am I doing wrong. Nigel Quote Link to comment Share on other sites More sharing options...
Denis Watkins Posted October 16, 2018 Share Posted October 16, 2018 Clear view is for life once you subscribe, and does give you 10 minutes free flight without subscription. Whatever your computer, you have to set up the tranny in games controller to accept all your stick movements And calibrate each axis The Transmitter is always SWITCHED OFF, the USB reads the sticks, but the tranny must be fully charged Have the USB connected between computer and tranny before start up After start up, get into peripheral set up and calibrate Edited By Denis Watkins on 16/10/2018 11:43:47 Quote Link to comment Share on other sites More sharing options...
nigel newby Posted October 16, 2018 Author Share Posted October 16, 2018 AS I said I can get nothing to work. I am using a e sky 0905a type transmitter. I have tried to set it up, but it does nit see it.Also I would expect it to show me flying sites and planes etc, but nothing. It has also downloaded two versions of clearview. Clr and Clr1. these appear on my desktop. Shall I delete it and try again Nigel Quote Link to comment Share on other sites More sharing options...
nigel newby Posted October 16, 2018 Author Share Posted October 16, 2018 I have not paid anything yet as I was hoping to try it out first. But nothing really works. Can not get any airfield, planes, or even the 0905a transmitter thingy majig to register. Do I need to get a code for the demo mode? Nigel Quote Link to comment Share on other sites More sharing options...
Frank Skilbeck Posted October 16, 2018 Share Posted October 16, 2018 You could try the Multiplex Multiflight free version, downloadable from here https://www.multiplex-rc.de/service/downloads/multiplex/software.html see if it works with your controller. Quote Link to comment Share on other sites More sharing options...
nigel newby Posted October 16, 2018 Author Share Posted October 16, 2018 Thanks, just tried it but the page for the software is not available. Guess I will just have to stick with FMS Nigel Quote Link to comment Share on other sites More sharing options...
Frank Skilbeck Posted October 16, 2018 Share Posted October 16, 2018 Posted by nigel newby on 16/10/2018 17:44:55: Thanks, just tried it but the page for the software is not available. Guess I will just have to stick with FMS Nigel It worked for me, clicking the download button at the bottom of the page and it starts the program download. Maybe your antivirus program blocks downloads. Quote Link to comment Share on other sites More sharing options...
eflightray Posted October 16, 2018 Share Posted October 16, 2018 Get a 'real model plane' and get out flying Quote Link to comment Share on other sites More sharing options...
Denis Watkins Posted October 16, 2018 Share Posted October 16, 2018 Posted by nigel newby on 16/10/2018 17:44:55: Thanks, just tried it but the page for the software is not available. Guess I will just have to stick with FMS Nigel Nigel, try again with everything OFF The transmitter is never switched on. With the computer off, plug in the USB and the jack into the transmitter The transmitter will then come on. Now start up the computer, and try again Quote Link to comment Share on other sites More sharing options...
Dave Cooper 3 Posted October 16, 2018 Share Posted October 16, 2018 Nigel, as well as Phoenix, I had a recent session with "Real Flight" at an exhibition near Bristol. It was also very impressive. Don't know about the cost, or, the available library of planes, but definitely worth a look... Thinking back, my version of Phoenix (v2.0) was running under Windows Vista. I'm now on Win 10 so it may not work for me any more - I'll have to load it up and give it a test sometime ! Good hunting Dave ps the model shop I bought from in Poole was off a main road in one of those little industrial estates. It had a swinging sign at the roadside saying "xxxxmodels this way". Take your tranny with you just in case ! Quote Link to comment Share on other sites More sharing options...
nigel newby Posted October 17, 2018 Author Share Posted October 17, 2018 Hi all, and thanks for all the help. After a bit of a cuffle I managed to down load a new driver, and now clear view works. I have had my ten minutes worth, so now will have to shell out for the rest of the programme. It seems ok and I am only after a bit of stick time while I am waiting for the weather to improve so that I can get a real model out there. I must get them all down from the loft and get a few photos of them. Some need identifying as I do not even know what they are. I guess I have about six or seven that are ready to fly with three or four more that just need finishing to get them airworthy. I have an electric glider that is munching at the bit to get in the air. All the rest are I/C models. Once again thaks for the help. Not so grumpy Nigel Quote Link to comment Share on other sites More sharing options...
nigel newby Posted October 17, 2018 Author Share Posted October 17, 2018 Hi Dave thanks for the info, will have a look on the web and see what turns up. I hope to take the glider with me as we are in a caravan with the rest of the tribe. So there might be a field where we can fly. Nigel PS do you still live down that way, if so where do you fly Quote Link to comment Share on other sites More sharing options...
nigel newby Posted October 17, 2018 Author Share Posted October 17, 2018 PPS |Dave, you should be able to upload version five for free, according to other chaps on here. Quote Link to comment Share on other sites More sharing options...
