GWS FW190
Kelly
Hi all,
I am about to start building the GWS 190.
This is my first foamy so I would value any advice on adhesives.
Is the glue supplied up to the job if not what would you recommend for sticking it all together, also what is best to use as a filler on a foamy????
Cheers everyone,
Kelvin
Cheers David, I'm still here, in body if not in mind .
Yep it is a foamie, is the GWS glue any good ? it shows it being used to glue everything on the model, but states in the things you need on the  instructions  that you also  need cyano and epoxy ?
