Nifty 50 Posted November 12, 2018 Share Posted November 12, 2018 This is my transmitter tray. It is for single-handed (left) use as you will see by the offset transmitter. It is a prototype and will be tweaked with use. The need for the tray arose when moving the throttle slider on the side of the transmitter, it turned around the neckstrap connection These are the bits: It went together like this: The Velcro strap to fasten the transmitter is a lipo battery strap. There were supposed to be blind nuts for all fixings, turns out that the M8 eyebolts were M8-ish, hence the nuts and washers. I am going to put some feet or sides on the underneath to stop them catching or the tray from rocking. It is easy to mount the transmitter with one hand, the handle drops into the slots and the straps holds it fast. The slot also stops the transmitter from rotating: I have used ideas from other designs to come up with this one. I am going to tie-wrap pipe insulation around the stomach curve and varnish the woodwork, The harness is a Tarot cross-over shoulder harness however it is awkward to put on one-handed when you have a coat on, so I have used a neck harness until I can get things sorted. I made this as I went along, if anyone would like dimensions that I can knock up a pdf drawing and email it. Quote Link to comment Share on other sites More sharing options...
Denis Watkins Posted November 12, 2018 Share Posted November 12, 2018 Magnificent Design and Construction Nifty, lettin your need guide you along For the stomach protection, use pipe insulation foam those long worm like sticks of foam tube are already split along the length and UHU the assembly Quote Link to comment Share on other sites More sharing options...
Chris Walby Posted November 12, 2018 Share Posted November 12, 2018 Great work and very nice design. Might be worth a call to a supplier/shop and ask about the double straps (x pattern) that some of the aerobatic/helicopter guys use to hold their trays still. No connection, but great service, so try Inwood Models or Midland Helicopters and have a chat Quote Link to comment Share on other sites More sharing options...
Josip Vrandecic -Mes Posted November 12, 2018 Share Posted November 12, 2018 Dear Mr. Nifty , this is a remarkable handicraft, in the ''reign'' of the internet and finished heartless products , you are really refreshing.Thanks for sharing and all the best Greetings from Adriatic Sea Jo Edited By Josip Vrandecic -Mes on 12/11/2018 08:14:40 Quote Link to comment Share on other sites More sharing options...
Ron Gray Posted November 12, 2018 Share Posted November 12, 2018 Try this for your harness, I use one with my Horus, really easy to put on and very comfy. **LINK** Quote Link to comment Share on other sites More sharing options...
Former Member Posted November 12, 2018 Share Posted November 12, 2018 [This posting has been removed] Quote Link to comment Share on other sites More sharing options...
