Neil James Posted April 19, 2019 Share Posted April 19, 2019 Hi. I’ve inherited a Galaxy Models Mystic with a webra .90 but as glow fuel is almost impossible to get here I’d like to convert it to petrol. Obviously tank and tubing will need to be replaced so it would be very helpful to get a photo of the plan of the nose section to help me decide which is the best bit of structure to cut out to get access to the tank. Ta. Quote Link to comment Share on other sites More sharing options...
Keith Berriman Posted April 19, 2019 Share Posted April 19, 2019 If memory banks are correct. Sarick have the plans and kits available an alternative would be Pegasus Models they have a similar model Quote Link to comment Share on other sites More sharing options...
ken anderson. Posted April 19, 2019 Share Posted April 19, 2019 hello Neil, I had a mystic, the top front deck is made from foam with a balsa skin...easily removed with a sharp knife to gain access. I've see mystic's with petrol engines in and they go like goodins…. ken anderson...ne....1..mystic dept. Quote Link to comment Share on other sites More sharing options...
bert baker Posted April 19, 2019 Share Posted April 19, 2019 I have a Mystic with a NGH 25 petrol in it,, superb to fly, if memory serves me right they recommended sheeting the tail feathers if put large engines in,,, mine isn’t and so far no issues Quote Link to comment Share on other sites More sharing options...
Bob Cotsford Posted April 19, 2019 Share Posted April 19, 2019 Mine had a hatch in the underside of the nose between the front formers, it also had another hatch under the tail so I guess that a previous owner hads found it needed tail weight when running a petrol motor in it. I used an OS 120 Surpass and it went quite nicely, not overpowered by any means. The tailplane was sheeted too iirc. Quote Link to comment Share on other sites More sharing options...
Paul C. Posted April 19, 2019 Share Posted April 19, 2019 This is not a scale plan but shows how everything is put together, shows a hatch at the bottom of the tank bay. Should be the easiest way to get to the tank above is foam veneered covered . I have a photo of the C of G and throws, will post them next . Cheers, Paul. Quote Link to comment Share on other sites More sharing options...
Paul C. Posted April 19, 2019 Share Posted April 19, 2019 Quote Link to comment Share on other sites More sharing options...
Neil James Posted April 25, 2019 Author Share Posted April 25, 2019 Thanks everyone, that's very helpful. I can cut with confidence now. I'm planning to fit an NGH petrol engine to it so good to know it's a suitable choice. I've had 3 Magicians and a Wizard over the years and I know how well they fly, including this one (now 20 years old) as it used to belong to a close friend, now sadly no longer with us, so I'm looking forward to seeing it fly again. I'm also definitely thinking that it's time I bought another Magician and fitted an electric motor! Quote Link to comment Share on other sites More sharing options...
bert baker Posted April 25, 2019 Share Posted April 25, 2019 Quote Link to comment Share on other sites More sharing options...
bert baker Posted April 25, 2019 Share Posted April 25, 2019 That’s a NGH 25, up front of mine, great combination Quote Link to comment Share on other sites More sharing options...
