Tony Harrison 2 Posted May 8, 2019 Share Posted May 8, 2019 After yet another botched attempt at flying solo*, rather than give up in disgust and do knitting or yoga instead, perhaps I should give flight sims another try. I had a version of Phoenix a while back, think I got it on Ebay, but never really liked it, very clunky graphics. Just looked at the Picasim site, free download I see but not sure if it works with a TX (mine's a Spektrum Dx6i) or mouse. Any suggestions about this or an alternative? *My few flights are measured in seconds before an ignominious bump or catastrophic vertical plunge: yesterday's lasted a teeny bit longer before my docile (it's flown a couple of times under supervision), lightweight high-wing trainer went out of control and dived into the ground, demolishing its nose plus some other minor damage. Hope the motor's ok. Quote Link to comment Share on other sites More sharing options...
Denis Watkins Posted May 8, 2019 Share Posted May 8, 2019 Phoenix can allow you to learn to fly Tony, and when set, is smooth running, and not notchy and Does work with the DX6i Set View, to " Ground in View ", allows spotting of the ground to land successfully With your determination, you will fly and land using Phoenix regularly, in short spurts, maybe 30 minutes when you can You, Will be flying in 8 Hours, IMHO Quote Link to comment Share on other sites More sharing options...
Dickw Posted May 8, 2019 Share Posted May 8, 2019 Posted by Tony Harrison 2 on 08/05/2019 16:14:27: ....... Just looked at the Picasim site, free download I see but not sure if it works with a TX (mine's a Spektrum Dx6i) or mouse. Any suggestions about this or an alternative? . Picasim works fine with my Jeti Tx via the usb connection, but I have no idea how it would work with Spektrum. Dick Quote Link to comment Share on other sites More sharing options...
Edgeflyer Posted May 8, 2019 Share Posted May 8, 2019 I haven't found any of the free sums to be good enough. IMHO Phoenix is most like real flying whereas Realflight is impressive but slightly less real feeling. There is a way of getting very cheap versions, but not strictly bona-fide. Quote Link to comment Share on other sites More sharing options...
Tony Harrison 2 Posted May 9, 2019 Author Share Posted May 9, 2019 Thanks chaps, very helpful. I'll look into Picasim further, and/or get hold of Phoenix - which I believe is discontinued but still obtainable from s/h sources. Best, Tony Quote Link to comment Share on other sites More sharing options...
