Andy C Posted May 17, 2019 Share Posted May 17, 2019 Been thinking about dding to my dremel a cordless version,but just seen in Aldi they have their own one. Aldi is £17,Dremel is anything up to £100. Do you get what you pay for? Thanks Quote Link to comment Share on other sites More sharing options...
Former Member Posted May 17, 2019 Share Posted May 17, 2019 [This posting has been removed] Quote Link to comment Share on other sites More sharing options...
Attilio Rausse Posted May 17, 2019 Share Posted May 17, 2019 i bought one from lidl so impressed i bought another, would agree with doc Marten buy it, not a lot to lose. Quote Link to comment Share on other sites More sharing options...
Julian Murch Posted May 17, 2019 Share Posted May 17, 2019 I have no experience of this particular thing but I have several Aldi tools - Routers, cordless drills, Jigsaw, Aligator saw and SDS Megadrill ! I have always found them to be very good and indeed I had 3 Black & Decker Aligator saws that all broke but the Aldi is now 4 years old and going strong (it will probably fail next time I use it but I have had my money's worth). I also have an angle grinder. I had a 24 volt cordless drill and the chuck jammed and I could not change speed. Brief phone call to the company and a postage label was emailed to me. Off to Germany and came back within 7 days with a completely new drill. Same with a floor steam mop a new one came very quickly. Quote Link to comment Share on other sites More sharing options...
Don Fry Posted May 17, 2019 Share Posted May 17, 2019 I had a Dremel cordless for a long time. Eventually the (NiCad) battery wore out. A fine tool, just balance the work rate against what a battery can support. i bought a Lidl replacement, Lipo battery. It's Ok for light load jobs, but if cutting or sanding, loading the drill is a nightmare. Slightly overload, and it stops. The old drill slowed, and you backed off pressure. So the 240 volt job does the real work nowadays. In fairness to Lidl/Aldi tools. If I were thinking of laying out the thick end of £100 on a cordless drill, I would like a grind with it first.. Quote Link to comment Share on other sites More sharing options...
will -0 Posted May 17, 2019 Share Posted May 17, 2019 I've had a woolworths corded one for ages. Not sure that's much help though Edited By will -0 on 17/05/2019 20:41:21 Quote Link to comment Share on other sites More sharing options...
John Robertson 3 Posted May 19, 2019 Share Posted May 19, 2019 I have both a Dremel corded and one of the Aldi cordless machines. I'm happy to use the cordless for most work, simply because it is convenient. It wheezes a bit if overloaded (that is, it stops!), but I haven't found that to be a problem. I simply unload the motor or go over to the Dremel corded machine. Quote Link to comment Share on other sites More sharing options...
Cuban8 Posted May 20, 2019 Share Posted May 20, 2019 I've had several cheap copy 'Dremels' over the years, and with the exception of the Aldi example that lasted all of 15 seconds from new before failing (money refunded no problem) they've been ok but nowhere near as good as the genuine article that I got from B&Q three or four years ago. It's a corded, mains power type and cost around £45 - personally I'd pay a bit more and go for the genuine article. Quote Link to comment Share on other sites More sharing options...
malcolm woodcock 1 Posted May 20, 2019 Share Posted May 20, 2019 I bought a Lidl 'Dremel' style rotary tool and it worked fine it just didn't have the same torque as the real thing but was still very useful. Quote Link to comment Share on other sites More sharing options...
timg Posted May 20, 2019 Share Posted May 20, 2019 Hi I have just bought the aldi cordless (dremel) £17 , more than happy with it , i don't have any experience using /owning a genuine dremel so i can't compare. I don't always think you get pay for hopefully you will be happy wih whatever you choose tim Quote Link to comment Share on other sites More sharing options...
Martin McIntosh Posted May 20, 2019 Share Posted May 20, 2019 I bought a cordless Dremel when I was working in the US in 1998 (had to get a 240 to 110V transformer). The 7.2V NiCad still holds full capacity, the drill permanently has a 1/16th" bit in it and is so small and handy it is untrue. Would not be without it. Current ones are not US built (Russian I think). I bought an Aldi (or was it Lidl) one as a spare. Works fine and can recommend it. Also have mains B&Q one (Skill) which is great for the heavier work and you can still get spares for them. Quote Link to comment Share on other sites More sharing options...
Phil Olson - Model Technics Posted May 21, 2019 Share Posted May 21, 2019 I've had the Lidl one for at least 3 years and its still working fine - I would highly recommend it Quote Link to comment Share on other sites More sharing options...
