Gary Murphy 1 Posted June 15, 2019 Share Posted June 15, 2019 Following tips and builds etc, it seems Aliphatic glue is a good choice. I have seen the very thing stuff used to wick into tight joins. My LHS had Deluxe models Aliphatic (but white?) and Super phatic. Got both. i have found the Super phatic not good to sand, it seems very rubbery , have i used to much or not allowed enough time? i used straight from the fine nozzle like CA. Quote Link to comment Share on other sites More sharing options...
Ernie Posted June 15, 2019 Share Posted June 15, 2019 Hi Gary, I reckon the sanding problem is an aliphatic thing. I do use it from time to time, but only when I need to move things about a bit, as it dries slowly Why not try cyano, The thin stuff dries instantly, with absolutely no sanding problems. The thicker ones are a bit slower, but no sanding problems ernie Quote Link to comment Share on other sites More sharing options...
flight1 Posted June 15, 2019 Share Posted June 15, 2019 I use super phatic for fine joints , it penatrates a bit and tend to leave it over night ( if the joint is too tight then it won't wick in the joint), also I don't use that much so it fillets/beeds the joint as thats not doing anythig . also i find it slightly rubbery so don't use it for jobs that need sanding afterwards, I perfer it to syno as no fumes. I use aliphatic glue for skinning/ scarf joints, sheeting etc as its stronger and sands ok all these glue have thier best aplications they are suited to. Quote Link to comment Share on other sites More sharing options...
George P. Posted June 15, 2019 Share Posted June 15, 2019 I use these glues a lot and find them very good. With the Superphatic, I use enough to soak in, allow it to dry then add some more if needed later. After each use I dry the area ( not the joint) with kitchen towel to avoid any problems later with sanding. Most of the time I use aliphatic but the Superphatic definitely has its uses and is good on some hinges/plastics/foam. Quote Link to comment Share on other sites More sharing options...
Peter Miller Posted June 15, 2019 Share Posted June 15, 2019 I use DeLuxe Aliphatic for all normal building, IT sands OK and much better than ordinary PVA. The Superphatic is intended for wicking in to joints Quote Link to comment Share on other sites More sharing options...
Jon Robb Posted June 15, 2019 Share Posted June 15, 2019 I use a lot of Titebond glue for models and other wood working pursuits. I find it sands very well, this too is an aliphatic glue so it could be down to the brand. Quote Link to comment Share on other sites More sharing options...
Former Member Posted June 15, 2019 Share Posted June 15, 2019 [This posting has been removed] Quote Link to comment Share on other sites More sharing options...
