TN Hurricane
Marko
Regarding Servos,
I have used Hitech 311's on most of my stuff, and 322's when they are available.
I purchased a retract servo for this build, as I didn't think that there was realy enough room for a standard servo between the wing and where I have mounted the fuel tank (as low as I can get it and still too high for my OS70FL (Air Bleed Carbie running inverted)).
The retract servo was not cheap, about AU$60 I seem to remember, but I have seen forced belly landings due to burnt out retract servos so I don't want to skinp there.
I was intending to use the Spectrum Servos that came in the box with my DX7, but I actually think they are lesser quality than the Hitech 311's... and that's saying something.
Cheers,
Hugh
Hello Timbo,
Thanks for the advice re sTowerPro servo's. Yes they are cheap and some report errors in centreing. Problem is the free plan states micro servos but the dimensions from the plan indicate (probably) a mini servo. The distance between the rib skin to skin is 30mm at rib W9. If you put the 6mm mounting square obechi through the holes in the rib you are left with 20mm below the mounting at the narrowest part to fit a servo. The other plan book states micro servo's but I cannot find a mini servo with a maximum depth of less than 30 mm. The plan does not give a side view of the mounting so I am working blind with this one. Futaba servo's I have looked at are around £25 each but seem to be too deep to fit.
I have looked at mounting a mini servo sideways on a hatch for access but think this would detract from the appearance.
Any advice would be welcome.
regards,
Bill R.
Hello All,
As a different approach to the aileron servo problem, if it's not too late, you could create a different servo mounting which puts the servo on its side with just the arm poking down through the undersurface. Using this method, a very large servo can be fitted. It also has the advantage of a tidier wing underside.  The following pictures show two views of a similar installation, albeit on a foam wing.
Servo on its side just under the wing surface.
 Showing the servo arm poking above/through the wing underside.
Just my two penn'orth.
Toni
This depends on the amount of rake ( and direction ) on the model. If the gear retracts "backwards" then the cog is shifting to the rear, so probably best to balance her with gear in this position - when gear is down, she will go slightly ose heavy, but this is obviously preferable to the opposite! Of course, the opposite is also true if the gear rakes forward on retraction
Edited By Timbo - Administrator on 28/12/2009 12:42:46
  • 3 weeks later...
I have had about 60 flights now, 10 with the .61 twostroke Evolution, and 50 with an ASP .61 fourstroke. The Hurricane really loved the fourstroke Much more gentle on takeoff, and beautiful sound in the air.
I am now fitting splitflaps to make her easier to land. I just cut out the area in the wing, and replace the 2mm balsaskin with 2mm 5-layer plywood,and hinge it in the wing.
I will make the servos and links inside the wing for better scale looks.
Here is a picture of her with the two-stroke engine...
And the build thread in Norwegian, with pictures...:
  • 1 month later...
gadyrdal did the split flaps make a big difference to the landing speed ?
I'm thinking of building a this one using a Hyperion Z4025 motor and 6 cell battery , is it possible to get the battery all the way against the firewall ? . I'm a bit concerned about weight as it only has a wing area of a little less than 600 square inches . What's  your models all up weight ?
I appologise for asking so many questions
Hi Allan.
I have not flown it yet after making the flaps. Still snow here in norway.
I think it will be no problem with electric power. The battery can stay were the tank is,
just behind the firewall. My hurricane weights 3,8 kilos.
The original drawings is ment for brushless system. You may have to add some lead in the nose, but still you will be under 4 kilos of weight.
Go for it!
  • 1 month later...
I am sure I read somewhere that the cut outs for the rear spar in W8 (on the special issue free plan) are in the wrong place... But did I remember to check before applying the CA?  Nup.  I had to make a second pair after prysing everthing apart again.
Never mind... A lesson for all.  Measure twice, os as many times as required and cut once.
Cheers,
Hugh
  • 1 month later...
Hello all,
I've recently finished my foam build of this plan -
http://www.modelflying.co.uk/forums/postings.asp?th=34350
It weighs in at 4 1/2 lb (including 8 ozs of lead to get the balance point right) and flies really nicely on half throttle with a 400W electric system - full power gives a nice big loop and spirited takeoffs. However, a couple of the onlookers said that it looks as if it is flying a bit tail down, suggesting that it is nose heavy. has anyone tried moving the balance point any further rearward from the 90mm point suggested on the plan?
  • 3 months later...
  • 3 weeks later...
Dear All,
Here's a photo of my Hurricane that is nearing completion, it's still got exhausts and small  bits to go on.  The tail is now painted but while he sun was out I couldn't resist a snap.
I bought the Sky RC air retract system for it, this cost £85 for the whole system including two sprung oleo's.  The engine is a SC 61 fourstroke, weather permitting and a good look over irst, I'll try and fly her this Sunday.  It's taken me over a year to finish, several other models have got in the way.  The main delay was over the retract system.  Originally I installed the mechanical system but this it never operated smoothly.  This was when it only had the top skin on too, I knew to finish the wing off would seal it all up forever.  So, it was put on hold and eventually I bought the Sky RC set, this wasn't fault free either.  One of the pistons was faulty but was replaced straight away by Moor Models.
It's got a lump of lead in the nose to balance it all out.  I'll let you know how or if it flies!
Bucks
Cool looking Hurri Bucks.
My build has stalled too while I try to work out the Retracts.  I have a servo for each side situated in the front of the wing outboard of each retract.  One side works a treat, but the other side keeps jamming form some reason.
So the wing is sitting on a shelf half built.
I may have to look into the system you have used.
I have an ASP 61 FS committed to this model... Basically the same engine as you.  How much lead did you need?
Hugh
Hugh,
I don't know how much it all weighed, the whole plane comes in at 7lbs 2 oz.  (1785g)  I've taken a photo of the engine, the lead is rolled up and hammered flat, it's then glued on using silicone sealant.  Then the whole lot is bolted together and then screwed to the motor mount.  Despite my best efforts I had to add more which is why there is a second lot bolted to the firewall.
The second photo is of the air botthe for the retracts, I wanted it all mounted on the wing so that none of the connections are touched when the wing comes off.
The note shows that the wing in total weighs 3lb 3oz.
I'll get anther flyer to look over it tomorrow first but if all goes well it awaits a flight tomorrow!
Bucks
Sorry,
 I meant to include a side view too.  She's sporting a new spinner and black painted prop, the tail colours have been painted and the exhausts are on.
The letters are a bit too big and bold but I cut them out myself, it shows Ft Lt Nicholsons plane from August 1940, he won the VC in it.  He was shot up and about to bale out when he climbed back in to shoot his attacker down.  He suffered serious burns and wounds, even being shot at by the Home Guard whilst parachuting down to earth!
Bucks
Hello All,
Its good to see that people are still quietly progressing (as am I) at their own rates.
I'm approaching the covering stage, so would also be very interested to learn more generally what methods people have used for their covering, and whether they'd do it again!
Regards,
Bill
Well, she flew but only just!  She staggered into the air, did a half turn back to the strip and dropped into the brambles.  Luckily damage was limited to the leading edges getting srapes and lumps in it.  It wouldn't/couldn't get the airspeed to fly.  It was an ASP 61 turning a 13 x 6 prop, total weight was 7lb 2oz.
The exhaust was bolted on before she flew by the way.
Will the engine turn a bigger prop or do I re engine up to an 80?  The would require a new cowl as it's a but longer and the gap twixt cowl and prop would be noticeable.
Oh well she's in a better state than I thought after seeing her go in so work will continue!
By the way she's covered in Pro film for the fuselage and tissue and water based varnish for the wings.  Then sprayed from tins and varnished over the top.  I like the tissue as it gives a nice sandable finish.
Bucks
