Glasshopper Posted December 11, 2020 Share Posted December 11, 2020 I use a Taranis 9d plus transmitter and recently had occasion to reduce the servo travel throws on the rudder and elevator of a model by 40% or more. When I checked my channel monitor I found that when the servos had reached their set limits the sticks still had 40% more travel which was “lost”. I had not noticed this effect before because other adjustments were so small I did not notice. My question is whether this is expected, it seems logical enough to me but my co pilots who are all Spekky users claim this would no happen on their transmitters. I have made the servo adjustments using “inputs” “mixers” and “outputs severally and independently but the result is the same. Quote Link to comment Share on other sites More sharing options...
Mike Blandford Posted December 11, 2020 Share Posted December 11, 2020 You should only need to change the values in "Outputs", these are the servo endpoint settings. Try creating a new model, checking the sticks operate correctly over the full range of movement, then adjust the Outputs Min and Max values to get the required servo movement. Mike Quote Link to comment Share on other sites More sharing options...
Richard Wills 2 Posted December 11, 2020 Share Posted December 11, 2020 I would add that if possible throw adjustments should be made mechanically on the linkage for best results before resorting to transmitter adjustments. Quote Link to comment Share on other sites More sharing options...
Bob Cotsford Posted December 11, 2020 Share Posted December 11, 2020 Have you calibrated the sticks? Also are you using a stabilised receiver, if so have run configuration on that? Quote Link to comment Share on other sites More sharing options...
Chris Walby Posted December 12, 2020 Share Posted December 12, 2020 Hi, as mentioned above control surfaces travel should be set up mechanically as far as possible and then a minor adjustment with the electronics. Primarily because very small servo travel with large surface movement results in very granular/notchy operation + adds more load to the servo. There are a multitude of different ways of setting things up and I have achieved the same effect as yours with Spektrum kit and managed to get rid of it as well, but its when I was trying to do things because I could not achieve it mechanically (easily). The joy of this hobby....lots of fiddling, reading the manual and someone (not me) will come a long and explain the easy way of doing it! Quote Link to comment Share on other sites More sharing options...
Glasshopper Posted December 12, 2020 Author Share Posted December 12, 2020 Thank you for all your help, I certainly take the point that surface movements should be resolved mechanically as far as possible before adjusting my TX. A combination of re-calibration and putting in a minimum value for my servo output adjustment seems to have done the trick. Quote Link to comment Share on other sites More sharing options...
