Bob Howard Posted December 16, 2020 Share Posted December 16, 2020 Can anyone help me? My 12 year old Futaba 7C 2.4GHz Tx is in great condition, and still works perfectly. The only issue is largely cosmetic - the aerial swivel is damaged. I have bought a new aerial in original the Ripmax packaging (part no. Y-9M99Z02203) which has the correct fitting, but is approx. 30mm shorter than the existing aerial. I am concerned that this may result in reduced range. I have emailed the Ripmax Service Centre for advice, but they are closed due to the COVID-19 pandemic. Does anybody out there know anything about this? Quote Link to comment Share on other sites More sharing options...
Martian Posted December 16, 2020 Share Posted December 16, 2020 Won't hurt to fit it then do a range check Quote Link to comment Share on other sites More sharing options...
Bob Howard Posted December 16, 2020 Author Share Posted December 16, 2020 Already thought of that. If the range is affected, it means stripping the Tx down twice. The connection to the circuit board (miniature spade terminal) is not the most robust in the world, I am reluctant to place it under any strain more often than I can help. Quote Link to comment Share on other sites More sharing options...
sharpy1071 Posted December 17, 2020 Share Posted December 17, 2020 I have a 7C which is broken, salt water got into it and messed it up. I'm going to throw it out the arial is 100mm from hinge to tip. Where are you? might be able to help you. Quote Link to comment Share on other sites More sharing options...
Alan H Posted December 17, 2020 Share Posted December 17, 2020 I would be very surprised if there is anything wrong with the replacement antenna from Ripmax. Remember that the active bit is only around one inch long (look at a receiver aerial eg a 617 Rx). All that is likely to be different with your replacement is that there is a bit less feeder in the antenna housing. Quote Link to comment Share on other sites More sharing options...
Brian Hammond Posted December 17, 2020 Share Posted December 17, 2020 I agree with Allan ,most of the cable is coaxial feeder . Quote Link to comment Share on other sites More sharing options...
Wingman Posted December 17, 2020 Share Posted December 17, 2020 I have two 7Cs the older one has a tapering aerial 100mm long from the hinge and the newer one has a almost parallel aerial 80mm long from the hinge so I reckon you will be OK with the new replacement. Edited By Wingman on 17/12/2020 16:12:16 Quote Link to comment Share on other sites More sharing options...
Bob Howard Posted December 17, 2020 Author Share Posted December 17, 2020 Many thanks guys. It looks as if Futaba changed the design at some stage, so the new aerial will be going on very soon. Quote Link to comment Share on other sites More sharing options...
Cliff Bastow Posted December 17, 2020 Share Posted December 17, 2020 Bob, I had exactly the same issues with my T7C. I fitted the shorter aerial and it works fine with no range issues. cheers Cliff. Quote Link to comment Share on other sites More sharing options...
