osprey6500 Posted May 2, 2021 Share Posted May 2, 2021 has anyone got a broken spectrum dx6i even smashed to bits will do just need the battery contacts out of the case please Quote Link to comment Share on other sites More sharing options...
Viv Letherby Posted September 21, 2021 Share Posted September 21, 2021 (edited) Check out the contacts from a Spektrum battery box from a DX7s or similar tx. They should be readily available, most are not used because they are not needed with a lithium battery. Edited September 21, 2021 by Viv Letherby changed text Quote Link to comment Share on other sites More sharing options...
Shaun Walsh Posted September 21, 2021 Share Posted September 21, 2021 (edited) 17 minutes ago, Viv Letherby said: Check out the contacts from a Spektrum battery box from a DX7s or similar tx. They should be readily available, most are not used because they are not needed with a lithium battery. Not sure if the contacts are the same shape but might be worth a try. Battery box Or cut out the old box from the TX back and glue the new one in, a bit drastic though. Edited September 21, 2021 by Shaun Walsh Quote Link to comment Share on other sites More sharing options...
Denis Watkins Posted September 21, 2021 Share Posted September 21, 2021 I recently got a DX6i back shell complete for £10 on eBay They are often advertised Quote Link to comment Share on other sites More sharing options...
