PAUL HUTCHINSON 2 Posted May 31, 2021 Share Posted May 31, 2021 Hi guys Can anyone recommend a good delta wing that flies well and runs on brushless/lipo. I'm looking for a new building project that can be built from plans that are comercially available. Many Thanks Paul Quote Link to comment Share on other sites More sharing options...
Bob Cotsford Posted May 31, 2021 Share Posted May 31, 2021 A Peter Russell 362 or the larger 363 would be easy to convert for electric depending on what size model you are looking for. Quote Link to comment Share on other sites More sharing options...
kc Posted May 31, 2021 Share Posted May 31, 2021 You could buy copies of the 363 or 362 from Sarik or download a copy from Outerzone together with the article. There are probably many other delta designs there if you look through Quote Link to comment Share on other sites More sharing options...
eflightray Posted May 31, 2021 Share Posted May 31, 2021 Hi Paul Assuming you like electric power --- Try a search on the Polaris Seaplane Parkflier, there are a few similar styles out there, one commercial model is the Northstar. It's easier to build, simple, has the motor on the fin, so can take-off and land on water, grass, snow etc. I built one, great fun. Ray. Quote Link to comment Share on other sites More sharing options...
PAUL HUTCHINSON 2 Posted June 1, 2021 Author Share Posted June 1, 2021 Thanks Guys, I will have a look at them all. Paul Quote Link to comment Share on other sites More sharing options...
Piers Bowlan Posted June 1, 2021 Share Posted June 1, 2021 (edited) The North Star plan and article is available on Outerzone too. An E-conversion works well with this design as you can avoid having to add lead in the nose, as you do with the IC version, by locating the LiPo well forward. Flies great too. Edited June 1, 2021 by Piers Bowlan Quote Link to comment Share on other sites More sharing options...
David Davis Posted June 1, 2021 Share Posted June 1, 2021 A bloke at my old club fitted an electric motor to a Peter Russell 363. 4S LiPo. it flew well and was easy to see being so large. Quote Link to comment Share on other sites More sharing options...
PAUL HUTCHINSON 2 Posted June 2, 2021 Author Share Posted June 2, 2021 Ok looks like I'm gonnna go with the 363, will order from Sarik. Thanks for all the help and comments, great to have so much help!! Quote Link to comment Share on other sites More sharing options...
