David Drew 1 Posted January 31, 2022 Share Posted January 31, 2022 The transmitter manual only references binding R2006GF receivers. Only just returned to model flying after several years away. Quote Link to comment Share on other sites More sharing options...
Denis Watkins Posted January 31, 2022 Share Posted January 31, 2022 You may know better, but on the chart TheT6J and the R3106GF are not ticked together. Quote Link to comment Share on other sites More sharing options...
J D 8 Posted January 31, 2022 Share Posted January 31, 2022 You are correct, they do NOT match. Only the 200--- RX's go with 6j and 8j. Quote Link to comment Share on other sites More sharing options...
kc Posted February 1, 2022 Share Posted February 1, 2022 Futaba users really need to see all of that chart ( just a portion is shown ) as compatibility is more complex than it seems. Some expensive Tx cover lots of different Rx while cheaper Tx often work with only some. One would expect the 6J and the 6L to cover all the same Rx as the 6K but they don't! Not relevent here but the 6EX works with more Rx than that shown on that portion of the chart - probably most FASST Rx. 6EX owners should think carefully before investing in extra Rx as if their Tx goes wrong it can only be replaced with extremely expensive Tx that cover the FASST range. Last time I checked I found my 6EX could only be replaced by an 800 pound Tx if the old 6EX fails. So any FASST Rx would be useless to me! Hence I bought a Spektrum set when I needed extra Rx ........ Quote Link to comment Share on other sites More sharing options...
Denis Watkins Posted February 1, 2022 Share Posted February 1, 2022 https://futabausa.com/product-support/receiver-feature-charts/ Quote Link to comment Share on other sites More sharing options...
David Drew 1 Posted February 2, 2022 Author Share Posted February 2, 2022 Thanks folks I bought an original immaculate Watty 4 with 2 transmitters and receivers of tinternet lesson learned 1 Quote Link to comment Share on other sites More sharing options...
