Erfolg Posted November 10, 2022 Share Posted November 10, 2022 Many years ago I was taught Technical Drawing and its conventions. Much later attended a course to learn about AutoCad. Perhaps a little earlier or maybe later I attended a course of how to use a early 3d modeling package. As part of my education much earlier I had been taught (with exams) about the concepts of modeling (in all of its forms) and used a wire frame modeling package. So where is this leading I can hear you think. Well, I am coping with using Fusion, although ofetn taken by surprise that mywork is not as useful and flexible as I would like and want. With AutoCAD, it is possible to draw a line relative to the "World Co-ordinates, then do ofsets to place other lines, click onto nodes (or switch them off) and do other things. The tools available are many and pretty obvious. When I stared with fusion I would place lines, from which I would generate other lines to create things such as intersection for circles and so on. Thereafter I use trim to get rid of these unwanted lines to leave a primitive, which I would extrude. Much to my surprise I later found that if I wanted to move a circle, by an amount, when using the modify listing, most of the dimensions were not there, they had gone with the erased construction lines, and so on. Now I do much the same, but dimension the object after, erasing most construction lines. I now have dimensions to adjust subsequently. Now all of this is tedious, I assume that there is a strategy that achieves what I want, that is more efficient in time and ease of design. So what is this strategy? I need educating on todays methodology, as much, if not all, is now irrelevant that I previously was taught and learnt. Yep, the world moves on leaving dinosaurs way behind, Quote Link to comment Share on other sites More sharing options...
Gavin Mack Posted November 10, 2022 Share Posted November 10, 2022 I mainly do 2 drawings and got a city and guilds in autocad for dos, with 2 screens, 1 for commands such as line, circle etc. and the other for the drawing. while it's not free any more I use a program called draftsight which has full autocad command line capability which I use all the time. I prefer typing line, circle etc rather than trying to find the icon on the toolbar they also do a 3d version of the software, again not free but a 30day trial is available Quote Link to comment Share on other sites More sharing options...
Ron Gray Posted November 10, 2022 Share Posted November 10, 2022 Erfolg try looking at Named Parameters and Contraints (both driven and driving), they are extremely powerful tools in Fusion 360. Quote Link to comment Share on other sites More sharing options...
