Skippers Walker Posted April 26, 2023 Share Posted April 26, 2023 The chosen power unit for this model is a Surpass C5055 600Kv with a 4S 3300 Lithium battery. My issue is which sensible ESC unit should be used with this motor? Confusion has arisen because when researching suitable information about ESCs to use, one source suggested a 60 mah, another 80 mah and a third 100 mah! Considering that gentle flight characteristics of this large model can any one solve my dilemma based upon practical experience please? Quote Link to comment Share on other sites More sharing options...
DaveyP Posted April 26, 2023 Share Posted April 26, 2023 I think you should be talking in Amps not mA ( milliamps) I believe that motor draws about 90A so I'd go for a 100A esc. Ther are more expert modellers on here who can give more precise recommendations. Regards Dave P 1 Quote Link to comment Share on other sites More sharing options...
Ace Posted April 26, 2023 Share Posted April 26, 2023 (edited) Never had that actual size motor but a similar Surpass rated at 65amp the same as yours. I ran with a 70amp ESC giving some headroom and with my chosen prop the watt meter read 57amp. So allowing for a little headroom I would suggest the 60amp ESC could be a little light unless you are going to prop it right down for a lower draw but then there will be a balance between weight and power required. C5055 600kv 1550 15-24v 65 14 1.5 0.0255 600 50x55 42x10 275 14x8/15x8/17x9 100 Edited April 26, 2023 by Ace 1 Quote Link to comment Share on other sites More sharing options...
Skippers Walker Posted April 26, 2023 Author Share Posted April 26, 2023 Yes of course you are right Davey about amps vs mahs, stupid typo on my part, thanks for your response. Quote Link to comment Share on other sites More sharing options...
Skippers Walker Posted April 26, 2023 Author Share Posted April 26, 2023 Thanks Ace for your contribution, I've a 60A and an 80A ESC in my workshop, so it looks like the 80A maybe the choice to make. I'll have to save up for a Watt meter me thinks! kind regards SW (Chris) 1 Quote Link to comment Share on other sites More sharing options...
