Keil kraft Falcon Electric Power Supply set up
The chosen power unit for this model is a Surpass C5055 600Kv with a 4S 3300 Lithium battery. My issue is which sensible ESC unit should be used with this motor? Confusion has arisen because when researching suitable information about  ESCs to use, one source suggested a 60 mah, another 80 mah and a third 100 mah!
Considering that gentle flight characteristics of this large model can any one solve my dilemma based upon practical experience please?
Never had that actual size motor but a similar Surpass rated at 65amp the same as yours. I ran with a 70amp ESC giving some headroom and with my chosen prop the watt meter read 57amp. So allowing for a little headroom I would suggest the 60amp ESC could be a little light unless you are going to prop it right down for a lower draw but then there will be a balance between weight and power required.
C5055 600kv 1550 15-24v 65 14 1.5 0.0255 600 50x55 42x10 275 14x8/15x8/17x9 100
Edited by Ace
  • Thanks 1
