Rob Blacknell 1 Posted May 25, 2023 Share Posted May 25, 2023 Hi guys, trying to get flaps set up on a 3 position switch (E) on a Futaba 9c. stowed/take-off/landing. Manual not much help, any ideas?? Thanks for looking, Rob. Quote Link to comment Share on other sites More sharing options...
Alan Gorham_ Posted May 25, 2023 Share Posted May 25, 2023 Have you assigned switch E to Channel 6 using the AUX-CH function? Quote Link to comment Share on other sites More sharing options...
Rob Blacknell 1 Posted May 25, 2023 Author Share Posted May 25, 2023 No, i have no idea where to start. Quote Link to comment Share on other sites More sharing options...
Alan Gorham_ Posted May 25, 2023 Share Posted May 25, 2023 Look at p39 of the manual. Quote Link to comment Share on other sites More sharing options...
Jon H Posted May 25, 2023 Share Posted May 25, 2023 In the aux-ch menu you can assign the channel to whatever switch you want. Personally i would use the slider on the side so you can feed the flaps in incrementally as you need. As flaps are not needed for takeoff this is a better setup and allows smooth deployment. You may also need to set up an elevator flap mix to trim the aircraft to fly with flap down. In the case of a WWII fighter you will need to mix in up with flap/gear deployment as the added drag and low speed tends to make warbirds drop their noses. This will vary model to model though. I have an FF9 myself and still use it for about half my fleet. Good radio and it has given me many years of service. Quote Link to comment Share on other sites More sharing options...
Rob Blacknell 1 Posted May 28, 2023 Author Share Posted May 28, 2023 Well.........i did manage to get 3 position flaps using a 3 position switch, but i could only fine tune on flaps up & flaps all the way down. I know it can be done, 'cos i've done it once & it took me about 3 hours to figure it out, but i can't seem to duplicate the settings this time around. In the end, i settled for Jon-laser's method & even that took a little fiddling. Hey ho, thanks for your replies chaps. Rob. Quote Link to comment Share on other sites More sharing options...
GrumpyGnome Posted May 28, 2023 Share Posted May 28, 2023 Have you tried using a custom curve? (Assuming you can create one....) Quote Link to comment Share on other sites More sharing options...
Rob Blacknell 1 Posted May 29, 2023 Author Share Posted May 29, 2023 15 hours ago, GrumpyGnome said: Have you tried using a custom curve? (Assuming you can create one....) No Grumps, not tried that. As far as it goes, Jon-Laser's way seems to be the best. It took a little figuring out as the sliders are not labelled like all the other switches. It was just a matter of selecting the correct switch/slider to channel 6 in my case. Got there in the end. Rob. Quote Link to comment Share on other sites More sharing options...
