Rocker Posted June 25, 2023 Share Posted June 25, 2023 Putting together a Seagull Edge 540 V2 180.I am a servo short for the rudder .I have some Futaba 3010 for everything else( but they are now all out of stock ) .Now I need adecent servo for the rudder .Was going for the Hi tec 325HB I do not intend to do any 3 D flying with it but want a reliable servo for the rudder Would the Hi tec standard 311 fo the job or do I need something a bit stronger like the 325 ? Quote Link to comment Share on other sites More sharing options...
Nigel R Posted June 26, 2023 Share Posted June 26, 2023 325 is way under spec. Hs485 is roughly equal to your futabas. I'd go a bit bigger though, hs645. Quote Link to comment Share on other sites More sharing options...
Jon H Posted June 26, 2023 Share Posted June 26, 2023 I think you would get away with the 325 but only if you used the smallest engine and flew fairly conservative aerobatics at a conservative speed. The sort of thing even a trainer or spacewalker might do. however the model is not really intended for that sort of performance and i would assume you are looking to push the envelope so i would go bigger as Nigel suggests. Savox 352 would be good, the 485 or 645 Nigel mentions are good as well. The new futaba u400 would fit the bill for sure although these aint cheap being nearly twice the price of the savox. Quote Link to comment Share on other sites More sharing options...
Craig Carr Posted June 26, 2023 Share Posted June 26, 2023 (edited) Hi Rocker I have that very model and fitted a JX HV7232MG. From kings Lynn It’s proved to be ultra reliable and no issues. Being flying the model regularly for 2 year now Craig Edited June 26, 2023 by Craig Carr Quote Link to comment Share on other sites More sharing options...
Martin McIntosh Posted June 28, 2023 Share Posted June 28, 2023 Savox 0253 or the faster 0252 are ideal for the Edge. I use them and they do not break the bank. 1 Quote Link to comment Share on other sites More sharing options...
