La Coupe Des Barons 2024 Depron Wing.
I am planning to build a new wing for my 2024 entry in La Coupe Des Barons, a jolly event for a French three channel trainer in which most of the entry ends up damaged or destroyed!
The wing will be to the overall dimensions of the standard Baron's wing though I might increase the span by 10% to gain a little more lift. I plan to build it with a D section leading edge, two balsa spars at the widest point of the wing section and a suplementary spar between the main spars and the trailing edge a la Super 60 and so many more. I will be using depron for the wing ribs for the first time and I'm thinking of using carbon fibre tube for the leading edge to impart a little more strength.
If I go for carbon fibre tube which glue should I use to stick it to the depron wing ribs?
For those unfamiliar with La Coupe Des Barons, here is a video of the 2017 event which will tell you all you know.
https://www.youtube.com/watch?v=vYlLvJC-MuE
