Neddy Posted February 11 Share Posted February 11 I can't get my transmitter to connect with receiver it's all Art tech gear. I didn't have a bind loop and went to a flying club to see if they had one. One of the members had one and we tried to use it but with no success. We plug the battery into the receiver. It send out three quick beeps and then beeped continually every few seconds . With every beep the propeller moved slightly. With the transformer turned on nothing is happening. Quote Link to comment Share on other sites More sharing options...
GaryW Posted February 11 Share Posted February 11 (edited) Sounds like the ESC beeping to indicate throttle needs to be reversed... reverses the throttle channel and that shud sort it Edited February 11 by GaryW 1 Quote Link to comment Share on other sites More sharing options...
GrumpyGnome Posted February 11 Share Posted February 11 Is this the first time you've tried to use it? Quote Link to comment Share on other sites More sharing options...
Neddy Posted February 11 Author Share Posted February 11 The reverse switch was set in reverse I changed it to normal and it started working. It meant the control was now going from off to flat out going from top to bottom. I changed it back to reverse and it now ran ok the control now goes from bottom off to top flat out which I am more used to. Thank you for pointing me to the reverse switch. 4 Quote Link to comment Share on other sites More sharing options...
GrumpyGnome Posted February 11 Share Posted February 11 Glad you got it sorted.. Quote Link to comment Share on other sites More sharing options...
