Wilco Wingco Posted February 22 Share Posted February 22 I have just bought one of the above intending to put it in my last vintage old tiler. Its a Majestic Major and the PAW outputs the same umph, according to the technical info I can find. Anybody got any comments on model size it will support, prop size and starting would be welcome. Mike Quote Link to comment Share on other sites More sharing options...
Shaun Walsh Posted February 22 Share Posted February 22 https://www.eifflaender.com/engine-instructions https://www.eifflaender.com/technical-details Quote Link to comment Share on other sites More sharing options...
Shaun Walsh Posted February 22 Share Posted February 22 (edited) https://www.martinwilkinson.co.uk/major_review.htm#:~:text=The Ben Buckle Majestic Major&text=40 2-stroke or .,between 5 and 8 lb. 700 watts for an 8lb model should be fine if not a touch overpowered. Edited February 22 by Shaun Walsh Quote Link to comment Share on other sites More sharing options...
Wilco Wingco Posted February 22 Author Share Posted February 22 Thanks chaps for all the info. I was gifted the airframe in a less than perfect state. Needed new wing tips , stripping of old covering but i wanted it to be diesel not glow. Just love the sound and smell.. See through wings and tail in yellow and sky blue trim. Here we go . Mike Quote Link to comment Share on other sites More sharing options...
Robin Colbourne Posted February 22 Share Posted February 22 Once the engine is run in, given that it is a very slow flying model with a thick wing, I would go larger on the diameter and finer on the pitch than those recommendations (8" pitch stated in instructions). Too coarse a pitch and you will have trouble getting the model down, as the residual thrust at idle will cause it to float and float. You still need plenty of ground clearance, as the undercarriage will flex a surprising amount and you don't want to break big props. Quote Link to comment Share on other sites More sharing options...
Frank Skilbeck Posted February 22 Share Posted February 22 If it's any help min flies on a 15 x 4 with a very old Laser 62, I agree an 8" pitch is more than you need. Quote Link to comment Share on other sites More sharing options...
